Results 1 to 8 of 8
Thread: Cooler AC
    Dec 16 2014
    Irvine, CA
    Cooler AC
    I noticed that in my 2002 Allroad the AC is not the best. I just recharged it and the best temperature out of the vents is around 68-70 degrees. When the car is moving maybe couple degrees less. It is super hot in texas now, 100+ everyday and it just can't keep the car cool at all. I don't have any climate control codes and the AC fan is spinning just fine. In my 2008 535i the AC is frigid and can keep the interior very nice. Is the Audi one just not as efficient? or is the compressor going out? I did hook up a gauge set and high side pressure seemed ok, but I am no expert.
    What does everyone else get out of the vents temperature wise in 100+ weather?
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    Refer to a PT chart for r134a and see what your low and high side should be at around 100f
    Then you can determine if you have restriction or faulty expansion valve or etc.
    Dec 16 2014
    Irvine, CA
    I have 55 PSI lowside and 320 psi highside, which is what it should be.
    Jun 10 2013
    United States
    I don't think you can get much more than 30 degrees below ambient. Do you have recirculate on?
    Sep 30 2015
    I cleaned my condensor and radiator with foam cleaner the other weekend and blew it out with compressed air. It can only help. Many people forget about this over the years. The airflow gets reduced over time and less heat is dissipated from the refrigerant as it passes through the condensor.
    Dec 16 2014
    Irvine, CA
    Quote Originally Posted by a4kamila6 View Post
    I looked at the condenser and it looks relatively clean. I will clean it just in case.
    Active Member Two Rings JBX's Avatar
    Jan 11 2015
    SS, MD
    Clean cabin filter? Clean(ed) evaporator coils? Clean and oil the fan motor--it may be spinning at a lower RPM than you may believe.
    My vents are in the low 50s on a 100F day on the S6.
    --jb
    02S6 6MT, A3 3.2 S-Line, 02 EVWE, CBX, Duc ST4S, 3rd Gen Rx-7, 96 Bronco Sport w/Kenne-Bell S/C
    Sep 30 2015
    Quote Originally Posted by JBX View Post
    --jb
    I was wondering how guys clean the evaporator. Condensor is easy.
