I've never used one, so I just want to make sure I do this right...
I am putting on 4 rebuilt calipers and changing to SS brake lines.
The Power Bleeder procedures indicate that one should first connect the bleeder to the reservoir and pressurize the system without any fluid in the bleeder to ensure there are no leaks. However, I'm worried that this may just push the old fluid into the empty space in the new lines and calipers and drain the reservoir too much and introduce air into the system or master cylinder.
So, shall I just skip this initial test and go for a full bleed?
I only have 1L bottle of fresh fluid, so I hope that should be enough.
Cheers.
