Lights are new but out of original box. Bought them for a project I never finished.
Application (Please consult your owner's manual for your application fitment type):
Fits a wide range of cars.
Most Applications require modification or custom fitting.
Please consult with authorized technician or consult with the owner's manual.
Description
This product is NOT the cheap "knock-off"brand kits sold by elsewhere.
It is not a simplistic and flexible LED strip with low powered LED, nor is it a low quality reproduction.
This is built with long term usage and functionality in mind.
*Includes wiring harness normally this is an additional $30
The product comes with many features including pulse width modulation for on/off signaling just like the factory units on the new Audi S5 and other new Audi models.
You can fit this to almost any vehicle with customization into the bumper to adapt the fixture into the lower valance or directly inside the bumper. However if you do perform any custom work, you are doing this at your own risk.
We not respnosible for any installation (please see our terms and conditions).
For optimal placement, please ensure that the light is no less than 35cm from the ground and no more than 90cm above the ground.
Also, to ensure proper coverage area, please ensure that distance between the lights is at least 60cm apart.
• DOT Legal
• Should have No Errors on any Vehicle
• Simple 12V Power/Ground Connection with cut off 3rd lead wire for signaling.
$200 + $25 shipping
Normally 299 + 30 for harness and also shipping, my loss your gain.
Buy on Ebay:
http://www.ebay.com/itm/222168329763...84.m1555.l2649
