Results 1 to 13 of 13
Thread: Gas help
    Jul 10 2016
    Dallas
    Gas help
    Does gas waste fast on this car? I just filled it up and didn't even last 2 days , haven't drove much ,do I have an issue?
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by Sergio0719 View Post
    We'll need waay more details than that to give you any kind of legitimate answer.
    -Adam
    Jul 10 2016
    Dallas
    Well just seems like gas is going by fast, if I pump half a tank it would be gone by end of the day I drive probably 15 minutes to work
    Jul 10 2016
    Dallas
    Also last time I pumped the gauge said I had no gas left in tank so I pumped some gas and when I turned the car on the gauge didn't read as full
    Jun 05 2015
    Maine
    What is your MPG?
    Also do you have a CEL?
    Jul 10 2016
    Dallas
    My mpg is 17 mpg , but I don't even trust it , I thought it was suppose to give you an average but every time I drive it goes as low as 10 and as high as 28 keep in mind it's still the same trip, what is CEL sorry I'm new
    Veteran Member Three Rings bakedcorn's Avatar
    Jul 27 2015
    Ontario
    As mentioned above we need more information.
    When you say you filled up, does that mean you put in 20 bucks worth of fuel or filled up the tank and from what level, 1/4 or half tank? "Filling up or filled up" is a relative term.
    Jul 10 2016
    Dallas
    FIled up $20 from 1/4
    Veteran Member Three Rings supple's Avatar
    Jan 27 2016
    I don't have a garage
    Woburn, MA
    $20 for 3/4 tank seems really cheap wherever you're filling up. Or your fuel gauge is reading wrong. Might need recalibration or worst case you have a fuel leak ( you should be able to smell gas if it is leaking)
    2013 S4 Monsoon Grey | APR Stage 2 Single Pulley | Roc Euro Intake | 034 RSB + Drivetrain Inserts + Control Arms | CR-15 | KW V1
    RIP 2007 Brilliant Black A4 Quattro | Unitronic Stage 1+ | Bilstein Sport + H&R Sport | Apikol Snub | GFB DV+ | 034 Turbo Inlet, Street Density Motor Mounts, RSB & End Links, Control Arms | Pipercross Filter
    Jan 27 2016
    Woburn, MA
    Don't have the exact number but I think our tanks hold about 16 gallons total
    Apr 24 2016
    California
    $20 / ~$3per gallon = ~6-7 gallons. At 20MPG, that would get you about 130 miles of travel, but if you just got the car and romp on it everywhere like I did, you could be getting 15-17MPG which would cut your $20 down to about 100 miles. 15 min drive to and from work could be 15-20 miles freeway, meaning you did almost 80 miles in two days. The math checks out, for the most part.
    FYI your engine type, trans type, driving habits, and car's mileage will all affect MPG. Also $20 might get you more or less fuel depending on how much it costs in your area.
    Jul 10 2016
    Dallas
    I fueled $15 today which was 5.50 gallons the gauge never went up ?
    Sent from my SM-N910T using Tapatalk
    Dec 14 2011
    Chagrin Falls, Ohio
    I always find that gallons per fortnight is the most accurate measure. Actually miles per gallon (miles divided by gallons used) would be more useful. I think they taught division in elementary school.
