There is a TDC timing mark on the crank shaft pulley and a corresponding mark on the crank cover. The mark appears in a 'window' of the cover.
Does the length (maybe +/- 4 mm) of the crank pulley cover window indicated the 'tolerance' field for the timing?
Example below: TDC mark on left edge of cover 'window':
http://i1273.photobucket.com/albums/...psm9p9cy92.jpg
