Results 1 to 20 of 20
    Oct 28 2014
    ON
    Clock and trip data keep resetting
    I often find my car with clock resetted and trip data lost. My battery is new, and good. I tried tightening a bunch of grounds and positive terminals under the dash. Today, for the first time, for a few seconds my dash died while my car was idling. Rpm went to zero, clock resented, but the engine kept running and radio was working.
    Anyone had this issue?
    Senior Member Three Rings MoparFreak69's Avatar
    Jan 31 2015
    2005.5 Audi A4 Avant 2.0T quattro
    Boise Id
    Cluster issue. Either the wiring to the connectors in the back of it have damaged/crappy pins or the control circuits are failing.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Here's a DIY to help with the cluster removal. Clicky click®
    Oct 28 2014
    ON
    I reseated the gage cluster connectors. Tightened more grounds.
    I also removed my fog hid ballasts in the unlikely case they mess with the electric system.
    Is the gauge cluster know to fail this way? Can it be fixed? I really don't like replacing gauge clusters due to miss matched mileage.
    Aug 26 2005
    Quote Originally Posted by daught View Post
    After you buy a used instrument cluster, get it "virginized". Then you can set the odometer displayed mileage to the exact same value as the old cluster.
    Your problem sounds like a loose power supply or ground circuit connection to the instrument cluster, causing intermittent loss of power supply to the instrument cluster. The ground circuits are part of the power supply circuits. If the external power supply connections are all good with no loose connections, then the problem is likely internal to the Instrument cluster.
    Vorsprung durch Technik
    Oct 28 2014
    ON
    Bump... so it started acting up again.
    The dash lights either go off or blink on and off for a few seconds. The radio and climate control lights do the same so its not just the dash. The car does not turn off and the radio continues to run.
    Does the lights switch affect those light? I am thinking I will start by removing the switch to see if it affects the lights.
    Worst comes to worst I have to trace the power from the fuse to the ground.
    Any better ideas where to start?
    Sent from my DROID Turbo using Tapatalk
    Nov 03 2011
    All Over!
    I would say it's a cluster issue. The climate control panel, and the radio being affected are red herrings - don't forget that lighting intensity is controlled by the rheostat (58d) in the cluster itself.
    I would first start by disconnecting your aftermarket HID ballasts, these have been known to upset sensitive onboard systems due to "white noise". If disconnecting these has no effect on your issues, replace the cluster. You'll need the SKC of your current cluster, as well as that of the donor, to have it coded, for IMMO and other settings.
    1986 Type 85 Audi 90 quattro
    Nov 03 2011
    All Over!
    I see you removed your foglamp ballasts, yet the problem persisted.
    Replace cluster, paying heed to what myself and Diagnosticator originally posted.
    Jan 24 2010
    Paramus,NJ USA
    Its not necessary to get the cluster virginized.You could adapt it as long as your able to extract the pin and set it to new mode 04 with some simple software rather than taking it to the dealer.Although I have never seen a RB4 cluster fail.As your sure you dont have any shorted wires going to the cluster??or anything tapped into the same wires for the cluster??Headlight switch turns on illumination on the interior of the vehicle.Inspect the headlight switch i've seen them burn up in the past causing some weird electrical issues.To remove,Turn on headlights,push the knob in and slightly turn counter clock wise to remove.Inspect all wiring at the switch,remove connector check for dark connection pins and or melted or burned plastic
    Ziddy Autowerks
    Veteran Member Three Rings Tugboatguy's Avatar
    Apr 08 2008
    07 S4 , 04 A4 1.8T Avant , 05 S4 VF SC
    New Westminster BC
    Sounds like intermitant bad ground to the cluster.
    Feb 27 2011
    Winnipeg
    If the car does not turn off when all of this is happening maybe a bad ignition switch?
    Oct 28 2014
    ON
    I did some more tests
    Pulling fuse 15 with car running does not reset clock, only resets on restart. Vent and drawer lights go out but radio HVAC lights stay on. Clock resets when car stopped. No alarms.
    Fuse 13 no HVAC or deck lights. Clock does not reset even car off. Burned out fog beeps when reconnected.
    Gauges lit and needles lit both fuses out
    When my cluster acts up the needles go out.
    So, there must be a third power source. Any idea where it comes from? Its not from the dash fuse panel since I pulled each one out one by one.
    I re-tightened my grounds under the dash. Next step would be to start disconnecting ground to identify the dash ground... or anyone know which one it is exactly?
    I realize its most likely a bad cluster but since its just a nuisance at the moment I like to try troubleshooting the whole system before I replace it.
    If it comes to replacement, can I install one from a salvage yard without a PIN? Does it have to be connected to the original ECU to pull the pin?
    Apr 15 2014
    Ottawa/Gatineau Canada
    I think you can pull the pin from a donor cluster if you install it in your car and use the correct software to read its pin /SKC
    I will be testing this as soon as I get some time I have a donor cluster sitting on my workbench
    Jan 24 2010
    Paramus,NJ USA
    Pin could be pulled with a laptop some simple software and a ftdi cable.Piece of cake.However you will need to pull both pins.As you will need to adapt the replacement cluster to the ecu.So rather than doing extra steps trying to read the pin from the ecu.You can pull the pin from the original cluster.Install used cluster.Pull the pin from that also.Then adapt using procedure in vcds.I say pull the pin from cluster because its easier and less of a hassle.Pins always match between ecu,cluster and keys.
    Ziddy Autowerks
    Oct 28 2014
    ON
    Oct 28 2014
    ON
    Did a bit more testing.
    Pulling fuse 15 with car running does not reset clock. Vent and drawer lights go out but radio HVAC lights stay on. Clock resets when car stopped.
    Fuse 13 no HVAC deck lights. Clock does not reset even car off.
    Gauges lit and needles lit wirh both fuses out.
    So what supplies power to the dash if not those 2 fuses?
    Also when the dash goes crazy and resets a bunch of times while drinving there is a grinding like noise coming from it. Kinda like a rusty small electric motor.
    Veteran Member Three Rings 5ktq's Avatar
    Aug 15 2016
    Western Canada
    Interesting. The needles are actually driven by little stepper motors, though as understand their failure mode is generally - doesn't move.
    though I suppose the speaker could be playing gibberish grindy noise while it is losing power?
    Oct 28 2014
    ON
    The needles work just fine otherwise.
    Oct 28 2014
    ON
    I am looking to swap it. Are all years B6 1.8t gauge clusters compatible with each other?
    Oct 28 2014
    ON
    BUMP I really need some help deciding what cluster I can use. I am pretty paranoid about it since the car can be "bricked".
    My cluster is 8E0 920 900 L RB4. I found one in an older A4 but it had 8E0 920 900 N. I know the last netter represents just a revision, but does it matter in any way here?
    Online it looks like 02 to 05 are good no problem, N or L. It does not even matter if it's 4 cylinder 6 or 8 as long as it's gas. http://www.jimellisaudiparts.com/pro...0920900NX.html
    car-part.com though only lists 2004 as compatible with a vin split 137001. Same with S4 clusters, 04 with a vin split at 137001.
    What's up with the discrepancy?
