Results 1 to 8 of 8
    Senior Member Three Rings B6ayfour's Avatar
    Jun 21 2015
    2014 S4 6MT, 1989 535i5
    LI, NY
    Parking Brake Self Adjusting mechanism POS
    Alright so after shoving just about every single pick, screwdriver, pliers, etc into the release slot in the self adjuster under the center console, to no avail, i have just about given up.
    Literally nothing has worked, any time i feel like i get close the button just doesn't move anymore. If someone can please let me know what i seem to be doing wrong that would be great because in every write-up/guide they seem to just barely even stick something into the mechanism and it just magically releases...
    If someone could tell me where i can find the stupid key for this thing i would greatly appreciate it because i called Audi and they apparently don't sell any tools..? Who would have thought, make thing that needs special tool to service, do not give access to tool
    The devil itself (not my car or pic)
    [IMG][/IMG]
    14 B8.5 S4 6MT Current Daily
    01.5 B5 S4 6MT SOLD
    04 C5 A6 2.7T S-line SOLD
    02 B6 A4 1.8TQM DG Sport Package SOLD
    Motoza Stage 2, USP front end conversion w/ Cupra lip, S4 rear bumper, 18" BBS CH, OBX catback exhaust, Genesis 380cc injectors, PSI concepts test pipe, Stratmosphere Hyperboost DV, CX Racing FMIC, Forge TIP, S4 BBK, etc...
    Jun 21 2015
    LI, NY
    Nobody?
    01.5 B5 S4 6MT SOLD
    Established Member Two Rings 123lilc's Avatar
    Mar 04 2015
    2002 Audi A4 GTX3071R, 2004 Audi S4 Avant 6M/T, 2008 Audi A4 Cabriolet,2018 L5P Duramax
    Champaign, Illinois
    When i did my E-Brake i used a coat hanger and jammed it in the hole and wedged it downwards I found that it works better than a flathead screwdriver. Not sure if that will help but give it a shot!
    Established Member Two Rings a4cruiser's Avatar
    Feb 03 2009
    99 gsx600
    St. Louis
    Quote Originally Posted by 123lilc View Post
    OP, did you try that? I need to give this a try. I've put it off far too long.
    If it isn't broke, don't fix it... EDIT. It will be broke soon.
    3.0 Group Member
    Veteran Member Three Rings chad99's Avatar
    Apr 22 2012
    Fremont, CA
    Did you search?, there was a DIY showing how someone dremeled a flat head screwdriver, I did the same thing and it worked great.
    Here it is http://www.audizine.com/forum/showth...ake-adjustment
    Apr 22 2012
    Fremont, CA
    Haha just noticed you found it nm
    Jun 21 2015
    LI, NY
    yeahh ive looked at about every diy. that one was the most useful but the pictures are dead so i just had to guess and it still didnt work. i have not tried a coat hanger but tbh im not re-attempting this until i get my hands on the key thats made for this mechanism. one of the techs at audi should steal one for me to use
    01.5 B5 S4 6MT SOLD
    May 21 2011
    b5 4.2
    Atlanta, GA
    Mine jammed up too.
    I drilled a hole thru the rivet and it exploded in pieces. Then I cleaned it, rebuilt it (it worked fine), and put a bolt thru the center to hold it back together. Works great now.
    ETA: It was a trick to get back together and reinstalled.
