A conventional oil change is always associated with spills and dirty hands. Therefore, this system has been developed with which you can perform an oil change completely safe and clean.
The stahlbus oil drain valve will easily replace the existing drain screw. When changing the oil, you unscrew the cap and put on the hose connector via quick release. Only when this is locked, the valve opens and the oil can be drained into the provided container.
When disconnecting the hose connector, the valve closes automatically and you only have to turn on the cap.
The Modern Oil Change
Fits:
Audi B5 A4 1.8T 1996-2001
Be sure to check out our -----> Oil Change Fundamentals <-----
Jason
