    Veteran Member Four Rings agentsmith988's Avatar
    Fry Sauce, UT
    FT require re-clocking?
    I've got a new FT F21L I'm trying to swap in today and it looks like it needs to be re-clocked. The coolant line doesn't align correctly with the WG mount (see photo). Is this a normal required step?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    PM sent.
    Aug 26 2005
    Drill a new hole in the actuator mount plate to align with the line bracket nut.
    Vorsprung durch Technik
    Dec 28 2006
    Western Maryland
    Unfortunately it's not that simple. If the waste-gate flange doesn't align properly the turbo support bracket and the SAI hard pipe attachments aren't going to align either.
    Fry Sauce, UT
    PM sent.
    Thanks for the help. Loosened the hot/cold side and rotated the center section. Worked perfectly.
    - Steve
    NKAWTG
    8V S3 Prestige | Sepang Exclusive Edition | APR Stage I HT | APR Carbon Intake | CTS Res Delete | H&R RSB 25mm | EMD 10mm/17.5mm Spacers | HomeLink Retro | Euro Aspherical Wing Mirrors | OsirUSA O-Shift EX Paddles
