Results 1 to 7 of 7
    Oct 09 2008
    01321 Airbag fault and parking brake malfunction, need advice
    Hey guys,
    I have a 2008 S5 (manual). When starting the car the other morning I immediately received the parking brake and airbag fault lights. My parking brake still works. From what I have read it seems that this is common and can be from the parking brake switch, the maf, a loose connector, or from a defective airbag module. I have ruled out the maf as I tried a brand new one, cleared the codes, and no luck (the wires looked fine and snug as well).
    I have two codes:
    049489 - No Communications with Airbag Control Module
    01321 - Control Module for Airbags (J234)
    I get the feeling that the airbag module has failed or is unplugged. Can anyone point to where the J234 module is? Or where the connectors to it are? All of the connectors under both front seats are snug and no obvious damage to any wires.
    Here is my vagcom scan, any input would be greatly appreciated because if I cannot figure it out it is going to the stealer.
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    06-Seat Mem. Pass -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    0E-Media Player 1 -- Status: OK 0000
    0F-Digital Radio -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: Cannot be reached 1100
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    1E-Media Player 2 -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    65-Tire Pressure -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (J623-CAUB) Labels: 079-907-560-CAU.clb
    Part No SW: 8T0 907 560 G HW: 8T0 907 560
    Component: 4.2l V8/4V H10 0009
    Revision: 76H10---
    Coding: 01140009180F0120
    Shop #: WSC 51613 001 1048576
    VCID: 3E734AB7A94642CE4C-806A
    1 Fault Found:
    U0151 - 008 -
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 123808 km
    Time Indication: 0
    Date: 2016.07.06
    Time: 09:31:52
    Freeze Frame:
    RPM: 653 /min
    Load: 29.4 %
    Speed: 0.0 km/h
    Temperature: 44.0°C
    Temperature: 22.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 14.478 V
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104) Labels: None
    Part No SW: 8K0 907 379 Q HW: 8K0 907 379 Q
    Component: ESP8 quattro H04 0170
    Revision: -------- Serial number: --------------
    Coding: 110500
    Shop #: WSC 06325 000 00000
    VCID: 479D2F53F69C0306FF-8012
    No fault code found.
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 AG HW: 8K0 907 064 AG
    Component: BCM2 1.1 H71 0132
    Revision: 00002001
    Coding: 0F0000
    VCID: 75E1959BDCF0C1965D-8020
    Subsystem 1 - Part No SW: 8K0 905 852 C HW: 8K0 905 852 C
    Component: ELVAUDIB8 H35 0039
    Address 06: Seat Mem. Pass (J521) Labels: 8T0-959-760.clb
    Part No SW: 8T0 959 760 B HW: 8T0 959 760 B
    Component: MEM-BFS H09 0043
    Revision: AA000000 Serial number: 00001001059363
    Coding: 00017025002C44110000
    Shop #: WSC 06342 000 00000
    VCID: 428B3E47DDBE262E28-8016
    Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
    Part No SW: 8T0 035 729 M HW: 4E0 035 729 A
    Component: Interfacebox H43 4610
    Revision: 00000000 Serial number: 340AH087504904
    Coding: 0025003
    Shop #: WSC 00999 444 64523
    VCID: 43853B4302A42F2623-8016
    Subsystem 1 - Part No: 8T0 919 609 D
    Component: E0380 BedienteilH08 0100
    Subsystem 2 - Serial number: 00000000034980
    Subsystem 3 - Serial number: 0118.12.070000000100010200˙
    Subsystem 4 - Serial number: 010200˙
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8T1 820 043 R HW: 8T1 820 043 R
    Component: KLIMA 3 ZONEN H05 0120
    Revision: C1000000 Serial number: 0109.01.081030
    Coding: 48022000
    VCID: 408F344FD3B2343E3E-8014
    1 Fault Found:
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 75
    Mileage: 124334 km
    Time Indication: 0
    Date: 2016.07.11
    Time: 19:58:39
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
    Component: BCM1 1.0 H21 0253
    Revision: 05021001 Serial number: 00000000076273
    Coding: 26001091461CAF010000080300003D3D0F1C13880001016100 0000
    VCID: 306F648F6312A4BECE-8064
    Subsystem 1 - Part No SW: 8T1 955 119 C HW: 8J1 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 040108 H13 0040
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
    Component: RLS H04 0002
    Coding: 02532C
    Subsystem 3 - Part No SW: 8K0 941 531 J HW: 8K0 941 531 J
    Component: E1 - LDS H07 0070
    Subsystem 4 - Part No SW: 8K0 907 410 A HW: 8K0 907 410 A
    Component: UGDO HL US H04 0060
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 75
    Mileage: 124334 km
    Time Indication: 0
    Date: 2016.07.11
    Time: 19:58:00
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 8T1 035 110 C HW: 8T1 035 110 C
    Component: MP3-Changer H41 0390
    Revision: 00041001 Serial number: AUZ5ZBH4555550
    Shop #: WSC 00000 000 00000
    VCID: 2A5B76E785CEDE6E00-807E
    Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
    Part No SW: 4E0 910 593 M HW: 4E0 035 593 F
    Component: SDAR SIRIUS H07 0160
    Revision: 00000000 Serial number: AUZ4Z7G0217103
    Coding: 0000100
    VCID: 3169618BA818ADB6C1-8064
    1 Fault Found:
    02635 - Tuner Not Enabled/Activated
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 75
    Mileage: 124334 km
    Time Indication: 0
    Date: 2016.07.11
    Time: 19:58:50
    Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
    Part No SW: 8K0 919 475 B HW: 8K0 919 475
    Component: PARKHILFE 4K H06 0010
    Revision: 11001001 Serial number: 75330801500482
    Coding: 200002
    VCID: 387F5CAF8B627CFE86-806C
    Address 15: Airbags
    Cannot be reached
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
    Component: Lenks.Modul H10 0012
    Revision: -------- Serial number: 90304HA8000EX
    Coding: 000016
    VCID: 3D714DBBA44059D655-8068
    Component: E221 - MFL H02 0003
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8T0 920 980 P HW: 8T0 920 980 P
    Component: KOMBIINSTR. H27 0216
    Revision: 00000000 Serial number: 72731U8A7
    Coding: 8B0501000B00D705020000
    VCID: 489F2C6FFB820C7EF6-801C
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 61
    Mileage: 123809 km
    Time Indication: 0
    Date: 2016.07.05
    Time: 21:01:07
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 75
    Mileage: 124334 km
    Time Indication: 0
    Date: 2016.07.11
    Time: 19:58:40
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 G HW: 8T0 907 468 G
    Component: GW-BEM 5CAN-M H08 0084
    Revision: FB102034 Serial number: 3400F07B09811D
    Coding: 000003
    Shop #: WSC 08101 444 53918
    VCID: 4581255BCC9011160D-8010
    Subsystem 1 - Part No SW: 8K0 915 181 HW: 8K0 915 181
    Component: J367-BDM H06 0150
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 75
    Mileage: 124334 km
    Time Indication: 0
    Date: 2016.07.11
    Time: 19:58:40
    Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl
    Part No SW: 4E0 035 785 F HW: 4E0 035 785 B
    Component: SG ext.Player H15 0850
    Revision: 00000000
    Coding: 010000
    VCID: 2B5573E34A34C766FB-807E
    Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb
    Component: MEM-FS H09 0043
    Revision: AA000000 Serial number: 00001001058835
    Coding: 00197B25002C44110000
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 M HW: 4E0 919 887 M
    Component: MNS US H51 1100
    Revision: 00000000 Serial number: 341LN077505034
    Shop #: WSC 08101 444 83282
    VCID: 387F5CAF4B627CFE86-806C
    Address 3C: Lane Change Labels: None
    Part No SW: 8K0 907 566 HW: 4L0 907 566 A
    Component: J0769_SWA_MasterH10 0040
    Revision: 00H10000 Serial number: 6PZ 009 014-02
    Coding: 0000004
    VCID: 74E7A89F178AD89E6A-8020
    Subsystem 1 - Part No: 8K0 907 568
    Component: J0770_SWA_Slave_H08 0040
    Subsystem 2 - Serial number: 6PZ 009 014-22
    Subsystem 3 - Serial number: 3F03.12.0700H0800000010242˙
    Subsystem 4 - Serial number: 010242˙
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8T0 959 793 J HW: 8T0 959 793 D
    Component: TSG FA H07 1301
    Coding: 011C13225E00120102
    Shop #: WSC 58421 001 1048576
    VCID: 50AF040F03D2C4BEAE-8004
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0107785718
    Coding: 0106029A007A44C500B000
    Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
    Component: GTO BF H06 0040
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H03 1301
    Subsystem 3 - Part No SW: 8R0 959 591 HW: 8R0 959 591
    Component: J245EE16SKB09 H01 0170
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 75
    Mileage: 124334 km
    Time Indication: 0
    Date: 2016.07.11
    Time: 19:58:39
    Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
    Part No SW: 8T0 035 223 T HW: 8T0 035 223 F
    Component: DSP Prem H14 0400
    Revision: 00H14003 Serial number: 34814006054704
    Coding: 020101
    Shop #: WSC 12336 024 394758
    VCID: 3F8D37B3AE4C4BC647-806A
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8K0 959 792 HW: 8K0 959 792
    Component: TSG BF H09 0149
    Revision: Serial number: 6
    Coding: 011C13225E002201
    VCID: 7CF780BFFFDA90DE22-8028
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 C HW: 8K0 907 801 C
    Component: EPB Audi B8 H03 0040
    Revision: 00000003 Serial number: 00000000055876
    VCID: 2F6D67F37E2CBB46D7-807A
    1 Fault Found:
    004 - No Signal/Communication - MIL ON
    Freeze Frame:
    Fault Status: 11100100
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 75
    Mileage: 124334 km
    Time Indication: 0
    Date: 2016.07.11
    Time: 19:58:39
    Freeze Frame:
    Voltage: 12.10 V
    Count: 67
    Speed: 0.0 km/h
    Hex Value: 0x0273
    Hex Value: 0x0001
    Hex Value: 0x1010
    Address 55: Headlight Range Labels: 8T0-907-357.clb
    Part No SW: 8H0 907 357 HW: 8H0 907 357
    Component: AFS 1 H01 0020
    Revision: 00000001 Serial number:
    Coding: 0000017
    Shop #: WSC 06324 000 00000
    VCID: 6FEDA7F37EACFB4697-803A
    Subsystem 1 - Part No: 7L6 941 329 A
    Component: AFS-Modul links H06 0002
    Subsystem 2 - Part No: 7L6 941 329 A
    Component: AFS-Modul rechtsH06 0002
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 T HW: 4F0 035 541 L
    Component: TUNER EU/US/RDW H42 0630
    Revision: 00000000 Serial number: 336AO087532419
    Coding: 0000002
    Address 65: Tire Pressure (J502) Labels: 8K0-907-273.clb
    Part No SW: 8K0 907 273 A HW: 8K0 907 273 A
    Component: J502-RDK H03 0250
    Revision: 00001001 Serial number: 12926772563894
    Coding: 0CD154
    Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
    Part No SW: 8T0 907 441 B HW: 4L0 907 441 A
    Component: J772__Rearview 0070
    Revision: --H12--- Serial number: 525PA8-J7Z901U
    Coding: 1000008
    VCID: 377D5F93467C73868F-8062
    Address 77: Telephone Labels: 4E0-910-336.lbl
    Part No SW: 4F0 910 336 H HW: 4E0 862 335
    Component: Handyvorb2 H18 1130
    Revision: 00000000 Serial number: 00000005019873
    Coding: 0010900
    VCID: 285F8CEF9BC2EC7E16-807C
    End-------------------------(Elapsed Time: 03:10)--------------------------
    The Awesome™
    Established Member Two Rings ChrisR14's Avatar
    Sep 08 2015
    2009 VW MK6
    Germany
    ECU15 will respond if it is connected to:
    1. +12v
    2. ground
    3. CAN high/low
    So check these and the fuse. If there is power and CAN your airbag module is faulty.
    2014 Audi S5 3.0T STronic // Estorilblue
    VAG Coding and retrofit expert
    Oct 09 2008
    Quote Originally Posted by ChrisR14 View Post
    1. +12v
    2. ground
    3. CAN high/low
    Thank you. Do you happen to know where the module (and fuse) is located so I can check for power? Do you also happen to have a pinout for the wiring harness?
    The Awesome™
    Oct 09 2008
    According this pin out, I don't believe I am getting power to J234.
    http://www.audi-portal.com/en/diagnostic/ecu_10490.html
    I checked the fuse in the trunk red fuse holder and it was fine. I am stumped as I cannot find a wiring diagram online.
    The Awesome™
    Senior Member Two Rings Tomieg's Avatar
    Aug 20 2016
    Did you ever get this sorted? I'm running into similar faults right now.
    Sent from my SM-G950U using Audizine mobile app
    JHM []S5 R.I.P.
    APR []////RS4
    Oct 09 2008
    Yes. The airbag control module was faulty and was subject to a recall campaign.
    The Awesome™
    Feb 09 2016
    co
    Mine comes on intermittently.. haven't really had any issues
