Hello all,
I have been using the archives of this forum to make repairs on my A4 since I bought it April. The threads here have been so thorough that I haven't had a need--until now--to create one of my own.
I started with an oil leak on the rear of the engine. Passenger side, leaking down onto transmission. The car came with a faulty breather system (cracked tube going into oil filer housing), and I later noticed oil dripping from the valve cover area onto the exhaust. I first replaced the breather hoses with a kit from ECS, then did the valve cover gasket, cam chain tensioner gasket and half moon seal in one go.
After around 1500 miles, I got the oil min light. No more oil from valve cover, and I can't feel any around the CCT. Now I am scratching my head. I suspect possibly a seal on the EGR valve, numbers 22 and 21 on the diagram below. While I am back there, I am thinking I will try to replace as many potentially suspect gaskets as possible so that I don't have to do it again.. It is very difficult for me to see the source of the leak without disassembling the pile of valves and hoses on the back of the engine. Anyone have any ideas as to what else may cause this sort of leak? It would be nice to buy all the gaskets at once, and disassemble only once to do the replacements. Advice is much appreciated.
EDIT: I should note, I have a B6 A4 1.8T engine code AMB
