Results 1 to 3 of 3
    Apr 07 2015
    Toronto, Canada
    Front Windshield Trim for A4-B5 - Directions for replacement?
    Hi, I have a 2001 Audi A4 and I just got new trim/water deflector pieces for the front windshield, the top and both sides.
    Parts 8D0845131E01C, 8D0854327C01C and 8D0854328C01C. https://www.ecstuning.com/Audi-B5_A4...ter_Deflector/
    Does anyone know of a thread or somewhere where's the directions on how to remove the old ones and install the new? I looked through a Hayne's manual and there's no mention of it.
    Thank you.
    Veteran Member Four Rings terraflata's Avatar
    Sep 14 2008
    '97 Audi 1.8TQM '97 Acura Integra 2002 Dodge Durango
    Chambly, Quebec, Canada
    The top part is usually installed at the same time as your windshield. You could technically replace it by cutting out the old one with an exacto trimming the new piece and securing it with urethane if you don't plan on replacing your windshield.
    The side pieces are just clipped in. You will need to pry the top or bottom up and pull it out. Just pressure holding it in.
    Apr 07 2015
    Toronto, Canada
    Thank you for the response.
