Results 1 to 7 of 7
    Jan 15 2010
    Santa Barbara, CA
    Going to get a DP, but might add full exhaust later. Which DP to get?
    I plan on going Stage 2 (going with the Eurodyne tune) shortly after my 5k service. I'd like to start with just the DP, but may add a full exhaust later. Since the OEM exhaust has a resonator, I assume most people get a DP without one. AWE offers both a resonated and non-resonated DP. I like the sound of the AWE exhaust, but don't think I'd want a non-resonated exhaust as it would be too loud.
    Should I just get a non-resonated DP? Is anyone running a resonated DP *and* stock exhaust with the resonator?
    I'd rather not cut my OEM exhaust up and install the resonator delete, since this is a lease and I want to be able to return to stock fairly easily.
    Any advice/input welcome!
    Feb 28 2015
    Cincy
    Bull X DP
    Registered User Four Rings EmmanueleDesign's Avatar
    Feb 11 2014
    2000 Audi S4, 1995 Audi S6
    Anaheim, CA
    Bull-X has the advantage that it is modular. So the included reducer will adapt to your stock exhaust, but can be removed later if you are upgrading to a full 3" system. Let us know if we can help out!
    Decat: http://www.emmanueledesign.com/colle...nt=22066303687
    Catted: http://www.emmanueledesign.com/colle...nt=22067188871
    Jan 15 2010
    Santa Barbara, CA
    Thanks, though to answer my question specifically, if I chose to add an aftermarket exhaust with the Bull-X DP, I'll then have an unresonated setup, correct?
    May 21 2015
    Pacific NW
    Quote Originally Posted by forbiddenbeat View Post
    I have the resonated AWE downpipe with the stock exhaust including the stock resonator. This setup is a bit louder than stock with a deeper tone but it's still pretty quiet overall. I tried it with the resonator delete and it's too loud and drones at certain engine speeds. I found it annoying after a few days so I put the stock resonator back on.
    2015 S3
    2015 A6 3.0T
    2004 Allroad 2.7T
    2004 Lexus GX470
    2008 BMW 535xi (sold)
    2006 A3 2.0T (sold)
    Feb 11 2014
    Anaheim, CA
    The resonator is located after the downpipe, so that would not affect it. You would still need to choose either resonated or non resonated when you purchase a catback.
    Veteran Member Three Rings Baggio's Avatar
    Aug 28 2013
    University Heights, OH
    I just added the Neuspeed catted DP and went from APR Stage 1 to 2. I went with the Neuspeed one because it guarantees no check engine light, and I don't have to add a test pipe file to my stage 2 flash to turn off the rear O2 sensor. I will eventually have to pass emissions here, so I didn't want to deal with swapping out DPs for testing. It also allows me to flash back to stock for warranty work and not have a CEL.
    2015 Daytona Gray Pearl Effect Audi S3 Quattro | Daytona 1 PKG | USP Motorsports interior LEDs |
    | APR Stage 2 ECU 93 HT & TCU tune | K&N | rain tray delete from airbox | REVO CF intake scoop | Spulen turbo inlet hose | APR turbo muffler delete |
    | APR IC | CTS Turbo inlet, outlet, and throttle pipes | Neuspeed 3" catted downpipe | 034 dogbone mount insert | 034 rear subframe inserts | Spulen intake coolant hose | ECS SS brake lines |
