Results 1 to 10 of 10
    Oct 13 2015
    Scotland
    Alternator belt change - what other preventative maintenance could I do?
    Gents
    Looking for some help please from you knowledgeable S4 people. Cars going in for annual service and I'm going to have the garage change the alternator belt, relay roller and tensioner assembly plus fit a 034 Motorsport snub mount. Is there anything else that should be looked at from a preventative maintenance point of view when the front bumper is off?
    Any comments or advice would be much appreciated.
    Thanks
    James
    Veteran Member Three Rings VroomTT's Avatar
    Nov 21 2013
    SE FL
    I'm sure others will chime in with more, but the headlight bulbs come to mind right away. If you have any flickering or any of them seem weak, go ahead and replace them all. Especially the main D1S bulbs. Better to do it while the bumper is off already.
    Senior Member Two Rings richB7S4's Avatar
    Jul 16 2013
    MD
    Recommend changing your VCG. Flush coolant and change expansion tank, if it shows early sign of cracks. Change the gasket on your lower oil pan if it shows leaks. Last but not the least, oil check valves and valley pan gasket.
    Oct 13 2015
    Scotland
    Guys
    Thanks for the quick replies.
    Quote Originally Posted by richB7S4 View Post
    What's the "VCG"?
    Oct 13 2015
    Scotland
    Is it the valve cover gasket?
    Jul 16 2013
    MD
    Yes.
    Oct 13 2015
    Scotland
    Is the valve cover gasket the same thing as a rocker head gasket?
    Oct 13 2015
    Scotland
    Thanks richB7S4. We are talking about the same thing.
    Senior Member Three Rings AllroadMass's Avatar
    Oct 30 2015
    Massachusetts
    Quote Originally Posted by James777 View Post
    Gents
    Thanks
    James
    How much are they charging for the work??
