Results 1 to 3 of 3
    Veteran Member Three Rings chad99's Avatar
    Apr 22 2012
    Fremont, CA
    17967 - Throttle Valve Control issues
    Hey guys looks like my TB is acting up, I get the 17967 code and it refuses to clear.
    Looks like I will have to give this a try
    http://forums.vwvortex.com/showthrea...t-(J338)-fixed
    Has anyone done this before?
    Apr 22 2012
    Fremont, CA
    Update to the issue:
    I can now sometimes clear the code, 060 does pass and say adp ok, I can hear throttle body moving.
    Sometimes she idles fine but next restart craps out with ESP traction lights, totally random.
    I will pull ECU and check/clean pins with battery disconnected, will update on results tonight
    Apr 22 2012
    Fremont, CA
    Found some slight green on the female connector ECU harness, cleaned with some deoxit D5, cleared the codes and did throttle adp.
    Drove it for a bit and problems seem to be gone, for now at least, fingers crossed.
    PO did mention something about water in ECU before and the box was missing the two rear screws, the insides of the box looked really clean, no signs of water or corrosion on any of the relays, put some Vaseline on the rubber gasket ECU top cover, reinstalled the cover and replaced the missing cover screws.
    Also ordered some deoxit d100 in spray form in case this problem comes back again.
