Hi everyone.
this regards the transmission with Audi designation (if that's the word) GBF. Aka ZF part number 1060 040 101 aka Audi part number 01V 300 052Q.
I badly damaged my transpan on a raised manhole cover immediately past a big dip in road. The dip made the car's weight come up and back down onto the damned thing.
I was 2 blocks from home and decided to attempt to get it into my driveway while fluid was still in there. I listened carefully for any bad sound while driving to home, heard none, bought new pan.
On install, I needed to get the plastic fill splash cap off of old pan and onto new pan. I search to no avail for instructions and then went at it VERY carefully. Got it off w/out breaking it. Lithium grease helped it pop onto new pan and I was able to add 6 quarts of fluid without much overflow.
I drove it and it's was in limp mode with PRNDS all lit on the dash display. Hopefully it only needs more fluid. I wouldn't be surprised if my extra driving after broken pan pushed more ATF out than 6 quarts.
The problem is that when I just now stuffed a hose up in the fill hole, it pushed the plastic splash cap right off of where it seats. WTF! Why didn't the new pan come with a new fill splash cap part and why is this designed to snap on as if plastic will always keep its flexibility? I'm sure that this isn't just off of where it seats, but to come off so easily it's probably broken.
And the key question: what is it even for and can I drop pan, throw it, replace pan and fill?
I do not believe that this part adds any volume at all to the capacity of the pan.I think that the same amount of fluid fits before overflow with or without this. Maybe that's where I'm wrong.
I know someone could say it's to direct whatever hose I put up there to bend in certain directions but I don't see how I need that kind of help. please just tell me where to point the end of the tube if it's important.
And what if I stick my finger up in there and hook that plastic thing and pull it till it breaks? That's what she said. Do you think there's any chance that it breaks into few and easily retrievable pieces? If it's not a necessary part, ill try this before dropping the pan.
If it is necessary, does anyone have experience with this? Do I need to glue it on or something?
