Results 1 to 32 of 32
    Veteran Member Four Rings dalmation53's Avatar
    Aug 19 2013
    Miami
    Baught Air compressor have questions.
    Hey guys I bought me an air compressor this thing is a beast and and i love it but the gun i baught is a piece of 💩...I tried to remove my wheel lug nuts and it wouldn't even remove them wtf. I baught that central pnematic from harbor freight for $30 thinking it was ok for diy and it sucked I realized I need a heavy duty impact wrench. I wanted to break loose mu cv axle bolts and no go. Tried to break my allen for the cv axle in the tip no go. What gun do you guy recommend so i can break anything loose? And please keep it less $100 not looking to spend $400 on a gun. This is what i baught. uploadfromtaptalk1468554500018.jpg
    Sent from my C5306 using Tapatalk
    Ivan
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    Dude bought is spelled with an "O". Sorry for not offering any real help, that just drove me nuts. Of course you used it no less than 5 times too
    2007 Porsche Cayman | 5MT
    Veteran Member Four Rings eMacPaul's Avatar
    Jul 25 2008
    Marysville, WA
    I use a 1/2" drive breaker bar and a 18" long or so pipe to use as a cheater bar.
    2007 A4 2.0T CVT Cabriolet S-Line Phantom Black
    APR, K&N air filter, Podi boost gauge, chrome-stripped grille, RS4 RSB
    Smoked side reflectors & markers, smartTOP, Eibach Pro-Kit, 12F/15R spacers, ER SMIC
    Xenon match DRLs, LED fogs, city w/ fogs, S4 mirrors, red LED interior, CC, 034 HFC + Magnaflow 14829
    Aug 19 2013
    Miami
    Quote Originally Posted by Ashtonts View Post
    Thanks dude i will keep that in mind for next time dude 👌😁
    Ivan
    Aug 19 2013
    Miami
    Quote Originally Posted by eMacPaul View Post
    I want someone to tell me which gun i should buy not tell me what to use if is not an impact. Lol
    Ivan
    Apr 24 2016
    California
    Quote Originally Posted by dalmation53 View Post
    What is the pressure regulator on the compressor set to? seems fishy a brand new impact gun can't break loose anything you mentioned, even if it was a cheap one.
    Aug 19 2013
    Miami
    Quote Originally Posted by RakkCity View Post
    It was set to 90psi even though i can go higher up to 150psi well i read reviews on it and is a piece of crap it has 1 star reviews lol. So i know is the gun 100% i have seen so many and undecided because i'm still a noob to this whole air tools thing. It was the central pneumatic 300lbs of torque my ass. I set my lug nuts to 50lbs just to toy around and the gun wouldn't even break that loose.but i have put air in my tires and painted some stuff and works like a charm.
    Ivan
    Mar 24 2013
    Oakdale, CT
    Get the 1/2" drive earthquake model from Harbor Freight. The $30 cheapo is weak, but I used the earthquake one to remove both a crank bolt and axle bolts. Always, always, always check the reviews when buying from HF. You should still be able to take the other impact back.
    http://m.harborfreight.com/12-in-pro...nch-68424.html
    -Adam
    Feb 15 2016
    Cambridge,Ontario
    A lot will also depend on the cfm rating of your compressor. . I use ingersol rand tools.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Veteran Member Four Rings JPT's Avatar
    Oct 11 2010
    '05 Kawasaki Ninja ZX12R
    Long Island/NY
    x2. I have this same impact. It was strong enough to break axle nuts on my jeep.
    FYI, your compressor is going to be LOUD... I have a 30 gallon, cast iron pump, belt driven compressor, has been going strong for 10+ years. LOVE having air tools...
    Feb 24 2004
    Minneapolis
    Ditto. I have a 24" pipe I put over my 20" breaker bar. You get out about 3 feet and the axle nut is no problem.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    That compressor you bought isn't the best, but it should probably do for most impacting. You'll want something with a CFM of 5 or more. Getting up to 8 or 9 is best, but you usually can't get that high with a small compressor like that.
    That impact you bought is weak shit. I wouldn't buy anything at Harbor Freight you don't expect to throw away. So, I agree with the above, get a reasonably priced Ingersol.
    Or, spend a little extra and get this thing. It is a beast. Mac re-brands them to their own name, or at least did a a few years ago. http://www.tooltopia.com/aircat-1200...cAZhoCrBnw_wcB
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Feb 15 2016
    Cambridge,Ontario
    wow Kevlar body armor ? is that for when you are changing a wheel in the combat zone under fire ? that thing looks awesome.
    1976 Yamaha XS 360
    Nov 07 2015
    2004 Jeep Wrangler Rubicon, 94 Z28
    Pennsylvania
    Just look at torque rating on the gun.. To break anything loose though a breaker bar is what you'd want. Any impact that can compete with a $60 breaker will cost hundreds.
    Oct 11 2010
    Long Island/NY
    Quote Originally Posted by redline380 View Post
    The 700 ft lbs rated one from harbor freight actually works very well for the home mechanic. I have been using mine for 10 years, just have to be sure to add a couple drops of oil (as with any air tool). I also have their 3/4 inch impact, and all 3 size air ratchets... They have worked well for years on the trails (in rain/snow) working on mine and many other club members rigs.
    Professional grade tools are nice, but for most home mechanics use them so infrequently that a lot of harbor freights stuff will work.
    (I used their 4" angle grinder and sawzall to do most of my custom metal work on my old jeep)
    Veteran Member Three Rings konarider94's Avatar
    Dec 28 2011
    14 EBR 1190SX
    kalamazoo, MI
    probably using a pretty long 1/4" hose too which creates a pretty big pressure drop from the compressor to the gun
    2018 A5 S-Line Manual
    Aug 04 2015
    Kansas City
    Dont forget to check craigslist for used impact wrenches. People unload quality tools on there all the time.
    Aug 19 2013
    Miami
    Guys thanks for the replies and recommendations now i saw a husky one rated at 650lbs of torque heavy duty one for $40 should that be enough i will buy it.
    Ivan
    Senior Member Three Rings 67Twisty's Avatar
    Jul 11 2015
    North Carolina
    Throw a liquid separator/knock-out on the compressor too. Living in FL with high humidity will kill air tools unless you get the moisture out of the line.
    Andy
    ‘17 Q7
    ‘07 Avant 6MTQ
    ‘03 525i Touring
    Veteran Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2015 Audi A3
    CO
    set your reg to 120PSI...
    2008 Audi A4 2.0T
    320awhp/420awtq...E85---UnitedMotorsports Tuned
    2015 A3 8v P-Stock
    2003 A4 Avant 3L-sold
    Veteran Member Four Rings i3oricua's Avatar
    Sep 17 2006
    2022 Kia Sorento; 2015 Ducati Monster 821 Dark
    Aurora, Colorado
    Quote Originally Posted by seal66 View Post
    This. I think you're compressor is set too low. Mine is similar in size if not the same and it breaks almost everything loose.
    Apr 24 2016
    California
    Quote Originally Posted by KJack View Post
    People unload stolen quality tools on there all the time.
    FTFY.
    Not that I care lol
    Jun 27 2011
    While normally I'd agree, a home mechanic has no use for professional level tools. Its a complete and utter waste of money. If your livlihood depends on them then they absolutely make sense. But for a home mech? no way. HF crap is absolutely fine. I have a decent quality Bostitch pancake compressor and use a variety of HF air tools with it. Yea they're not the best, but they absolutely get the job done. I used one of their brad nailers for work in my house and it was awesome. Sure there are better ones but for my uses it was just fine.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    I saw it mentioned before but if you look at the max PSI for a compressor it is almost false advertising because that doesn't really help much. You have to look at the amount of flow @ 90psi (or whatever you gun/impact needs) and see if the compressor and gun match up and will work well. You can have a gun that will run 300ft/lbs under 6CFM but if you are running it at 3CFM with a 1/4" hose it will not perform as mentioned.
    You have to make sure all elements line up. Basically saying a car can hit 180 mph, but if that car doesn't have the proper amount of gas, it sure won't move.
    Side note: HF tools work decent, sometimes you do get a dud, return it and try again if you have everything else set up proper and make sure you have the pressure reg on your tank set as well.
    Good luck with the air set up. I would go with a retractable hose reel as well :D
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
    Mar 22 2014
    '11 A4 2.0 62k/ '07 A4 2.0 123k/ '06 Passat 2.0 132k/ '05 A4 1.8 145k/ '00 Jetta VR6 52k/ '04 S60
    Cleveland, Ohio
    I figured I would chime in. Although you are asking for an impact to work with your new compressor I must recommend their electric 1/2" impact. It's like $35 and works well. If stuff is really on there you may have to break it free but I cant think of anything it wouldnt take off for me. I work on cars quite a bit more than the average person and live in the rust belt Ohio and it's pretty bad ass. Not to mention (depending on your setup) it's usually easier to run a 100' extension cord outside than uncoiling and recoiling a hose. Plus you don't have your ears blasted off by the compressor kicking on every five spins of the impact.
    Basically I'm saying sure find a good pnumatic impact but if you have an extra $35 this is on my buddies and my "best tool deals" list. Add IRWIN extractors and you're set . Going off subject. But I picked up the craftsman nextec 12v drill and 1/4" impact and I use the impact everywhere. It drives a wood screw straight through a 2x4 but also is small and light so working on cars with it is hugh.
    Next investment is a cordless battery powered 1/2" impact but would probably go with a snapon or ingersoll which is $400-$700 and hard to justify over a $12 breaker that does the job.
    Veteran Member Four Rings vwblackb5's Avatar
    Jun 26 2007
    New Jersey
    In lieu of an air compressor, an 18V 1/2" square drive impact wrench can do a good job as well. I use this model for swapping winter/summers and have no problems breaking lugs loose. Also, definitely suggest using Torque limiting sockets then obviously finish with torque wrench, if you end up tightening with the impact.
    IIRC, CV bolts and front hub bolts are one time use, but are torqued at 140ft-lbs/190 Nm plus 180° for a M16 bolt. So get something with max torque rating above 200ft*lb.
    16 B8.5: S4 | Premium Plus | Ibis White | PNY | PPS | GH2 | 1BL | Black Nappa | CTS
    99.5 B5: K04-015 / GIAC PC-16 / 315cc Genesis / Custom FMIC / 034 TP / TT Downpipe / Jetex Catback / Forge 007P / ECS AFPR @ 2.7Bar / ABD Tuning Intake / Blinktek Heatshield / Koni FSD / Eibach Pro Kit / SouthBend Stage 2 Endurance OFE HD / 312mm Slotted A8 BBK
    Feb 15 2016
    Cambridge,Ontario
    Did vwblack actually post something ? I think I was distracted.
    1976 Yamaha XS 360
    Aug 17 2013
    Rossford, Oh
    Snap-On impacts are beasty thought.. that being said, mine was gifted to me lol.
    Jan 02 2014
    LaSalle, Quebec, Canada
    Using a Snap on 1/2 electric gun and an Ingersoll 2235 Ti Max, pretty much the best setup in my opinion!
    Feb 08 2012
    Dallas, GA
    This is the one I got. It's a beast and was on sale for $119 with the hi-cap battery and charger. I debated getting air tools and a bigger compressor, but I don't really have the space and this is way easier than lugging a hose around. Plus, you can take it with you if you need to!
    Mar 01 2013
    USA/VA
    This is the one I was looking at: http://www.homedepot.com/p/Husky-1-2...4480/203458750
    It has some good reviews.
    • 06 Audi 2.0t Quattro Avant - Drop in K&N, Sony App Radio, 034 Snub Mount & Bracket, Carbon Fiber Interior Wrap - Sold
    • 01 Audi A4 1.8t AWM Quattro - AWE Boost Gauge, 18" Avus S4 Rims, 8000k HIDs, 3000K HID fog light mod, Pioneer Double DIN, Krauto Interior LED Kit - Sold
    Veteran Member Three Rings StatusQuo's Avatar
    Jun 15 2016
    Northern California
    I almost got this HF compressor until I saw the Husky 26Gal. They take Lowe's coupons too. I got mine for 220 about.
    But the earthquake series pneumatic tools from Hf are beast. Well worth the money all day. Make sure you maintain them. Oil them up before using them for the day.
    B7 Audi A4 Quattro - Built. Not Bought.
    Upgraded HPFP | RS4 Injectors | RS4 LPFP Controller | 175 Bar PRV | 50/50 E85 | Straightpipe Exhaust | Cold Air Intake | Big Turbo | Front Mount Intercooler | -- The Maestro Community Project --
