Results 1 to 13 of 13
    Senior Member Two Rings meisladrs's Avatar
    Jul 14 2013
    Huffy 10 speed And rollerblades , dead hipsters
    Denver ,Co
    FS O34 front swaybar end links
    Used for just a little time maybe 1000 miles , didn't like the sound so switched back to s4 sway bar ends
    New there 155 plus shipping
    100 shipped
    2012 a4 avant. APR STG2, Apr turbo back, O34 mounts/ braces, And skid plate for Denver crappy roads, Blue line coilover -no Bueno, 19" lm reps, Hid Clear lens swap, APR carbino intake, eurocode turbo pipe
    And slipping 8 speed trans
    So back to my tricked out huffy 10 speed
    past rides b6 a4 avant ,Mk4 Jetta - ex destroyed, 1963 bug
    Jul 14 2013
    Denver ,Co
    Bump
    Jul 14 2013
    Denver ,Co
    Bump
    Veteran Member Three Rings PBKIDD24's Avatar
    Apr 30 2015
    What kind of sounds were these making?
    2015 S4 P+ Daytona Grey Pearl Effect
    APR / Milltek / Bilstein / Eibach / 034Motorsports
    Build ThreadInstagramFlickr
    Past Cars: 2015 A4 Build Thread
    Jul 14 2013
    Denver ,Co
    They made a clunking sound, sounded like something was loose Ended up being the swaybar
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    I think that sound is the front sway bar bushing saying "grease me". If the rubber bushings are not packed with grease, or the bar wrapped with Teflon tape, there will be a popping / clanking noise.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Senior Member Two Rings redeye_jedi's Avatar
    Dec 12 2015
    Sk8teboard, Audi B8 A4 Quattro stg2
    Were these driven in snow/salt?
    / AUDI A3/8V Quattro / 034 Motorsports Stg1 ECU/TCU/ ST's /
    18” Split 5’s / 235/40/18 conti’s
    / AUDI B8 A4 stg2 / kw’s, sway bars, intake / 19” Black Peelers /
    / 245/35/19 Federal’s /
    Senior Member Two Rings TurboNate's Avatar
    May 16 2015
    El Cajon/CA/San Diego
    Quote Originally Posted by blbroo View Post
    I just had my upper control arms replaced and I'm having the same sound, could they be the issue?
    2009 A4 Premium+ Quattro
    APR Stage 2 | CTS Turbo High Flow Cat | Custom Intake System | AG 19x9.5 m580 w/ 10MM Spacers In Rear | RS Mesh Grill | 5% / 20% tint
    AKA: NathanMansoor
    Jul 14 2013
    Denver ,Co
    They were run in the rain here in Denver
    I greased my sway bars after the local shop that installed them didn't do so on install
    Jul 14 2013
    Denver ,Co
    Bump
    Jul 14 2013
    Denver ,Co
    bump
    Jul 14 2013
    Denver ,Co
    Bump
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    Quote Originally Posted by TurboNate View Post
    If the person that replaced your upper control arms didn't preload the cars weight before tighten the upper bolts where the rubber bushings are they will creak and cause premature wear on them.
    Sent from my SM-G900W8 using Tapatalk
