Results 1 to 6 of 6
    Veteran Member Four Rings FastEddie's Avatar
    Apr 01 2012
    Queens
    Video i made from QDM 2016
    Just a quick video i put together from Quattro de mayo 2016. The B7's in the video are Me (2008 DTM S4) and Komseh (RS4). Also in the video are MK2 TTS and TT comp pack, MK3 TTS, RS5 (shonseb) and a B5 S4 Avant.
    https://youtu.be/D5cOg3DoeyU
    SUSPENSION-KW V3-Hotchkiss RS4 sway bars-034 Adj UCA-034 strut mount-034 F&R end links-034 motor mounts-034 Snub mount W/bracket-034 Trans mount l BRAKES-ECS Stage 4 BBK-ECS rear rotors & lines, Hawk pads l Engine-JHM Tune-JHM 6 rib pulley-Milltek catless DP's-FI exhaust l EXTERIOR-RS4 black grille-Custom headlights-LED city & DRL lights-ECS LED tail lights & plate lights l INTERIOR-Custom steering wheel-SRP pedals-ECS LED lights-MOMO shift knob-Gen 2 RNSE & AMI l WHEELS-OEM RS4 W/ Michelin PSS
    Veteran Member Three Rings esimp2k's Avatar
    Jun 17 2009
    Maserati granturismo sport
    That's good stuff. Would have loved to hear more of the cars and less of the music.
    Apr 01 2012
    Queens
    Yes well, if you own a go pro you know its hard to capture good sound. The car sounds you do hear are from Mine and shons exhausts. Otherwise from the positions the go pro's are in you would hear mostly wind noise.
    I do have a 30 foot mic, but on my car the exhaust DB level is so loud that the mic becomes muffled and sounds like shit. I was gonna let the RS4 borrow my mic but forgot it on the day we went out to use it. Trying to find a good mic and location to get videos is an ongoing process. Most of the videos were wind noise which is why i put the music in. We were there to drive and the video was 2nd on our mind.
    Any suggestions and i would gladly try them out.
    Jun 10 2016
    2005 Audi S4 \ 2010 Honda Fit
    Germantown, Maryland
    Good stuff!
    Lots of perspectives and the drone shots are great! The quick cuts work out nicely for the footage shot. Agreed on the GoPro audio and movement causes lots of wind noise. Car sounds are better sitting still. I've shot stationary video like concerts with a realtively cheap mic:
    https://www.zoom-na.com/products/fie...handy-recorder
    This mic has a standard 1/4 inch camera mount so you can mount it near your gopro. Maybe a stationary 'road side' mic with several car passes?
    Long battery life and excellent quality - but you would probably have to put a wind sock to help reduce the breeze - which I do not own nor do I have any first hand experience:
    https://www.zoom-na.com/products/pro...sal-windscreen
    Keep the camera rolling and thanks for sharing!
    Dave
    Apr 01 2012
    Queens
    Yeah thats the plan. This is my first video ive edited in years. I plan to start making them a bit more often. Thanks for the links.
    Veteran Member Three Rings SprintBlueWorld's Avatar
    Sep 16 2013
    08 Hemi Big Horn, 08 Honda civic, 08 Audi S4 Cab MT6
    Pa
    What a blast! I got a ride like that not too far from here at Hopewell Furnace, but probably nowhere near as long as it is down there. Good stuff!
    Oem RS4 Reps, RS4 Pedals, KN Air Filter, JHM 93 tune, JHM Intake Spacers, Rear Stoptech Slots & SS Brake lines, JHM 6-Rib Pullys, 034 Snubby Bracket, Dimple/ECS Oil & Diff Magnetic Drain plugs, Apikol Diff Mount, 034 Carrier Mount Inserts, Corsa RSC Cat-Back, 034 Sway Bar & End Links, Piggies in a Blanket, Front JHM LW Rotors, Hawk HPS pads, 13mm Spacers
