Results 1 to 15 of 15
    Established Member Two Rings WJN S4's Avatar
    Jan 21 2014
    2013 Audi S4, BMW M4, BMW X5 M
    NJ/NYC
    S4 Badge - Trunk Placement Measurements
    Need a favor boys:
    Can someone get the measurements for where exactly on the trunk the "S4" badge exactly goes like from the factory?
    In other words:
    "S" is ___ inches from left trunk lid edge, ____ inches from bottom trunk lid
    "4" is ___ inches from S badge, ___ inches from bottom trunk lid
    or something along those lines.. any help is appreciated.
    Thank you!
    2013 Audi S4 | EPL Stage 2 ECU & TCU | Stoptech | Hawk | Eurocode | aFe
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    Edit: Just took these off my B8. Should be about the same for both 8 and 8.5 models. Hope it helps!
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    _
    2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW
    1999 A4 Avant | Cactus
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    Quote Originally Posted by DannyDeez View Post
    Thanks for posting Will come in handy when I replace my trunk badge this weekend.
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by mrmomo313 View Post
    FWIW, when I replaced mine with black gloss ones (post)
    I just taped off where they were stock with painters tape, pulled the old badges off, cleaned with alcohol and stuck the new ones on.
    Saved me from measuring and possibly misaligning them
    Geoff
    Veteran Member Three Rings Pared's Avatar
    Oct 28 2010
    Just mask off the edges with painters tape. Much easier. I do this all the time.
    Oct 27 2010
    Michigan
    Quote Originally Posted by whiped View Post
    That will be much easier. Thanks for the tip
    Mar 21 2015
    You could've made a template too if you wanted to clean the area real well. Think smarter not harder.
    Apr 05 2016
    Portland, OR
    I thought about it. Decided a template was too much effort.
    It was easy enough to mask up the edges, peel off the badge, clean under it (you can peel up sides of the tape to clean better), then stick on the new badge.
    YMMV but, that was the most effective solution for me.
    Geoff
    Mar 21 2015
    I agree, I was referencing the op.
    Jan 21 2014
    NJ/NYC
    Thank you everyone for your help
    Car went to the body shop, cement sprayed all over from construction site.
    Thought body shop had these measurements/templates.. but then asked me for them, which is surprising given they are well endorsed by many forum members, including Detailer's Domain..
    Mar 21 2015
    Quote Originally Posted by WJN S4 View Post
    That straight up blows
    Apr 05 2016
    Portland, OR
    Wow, I'd be pissed.
    Make them cover a full detail as well.
    Geoff
    Sep 11 2004
    16 Q5
    Westchester, NY
    Welcome!
    Jan 21 2014
    NJ/NYC
    Wow, I'd be pissed.
    Trust me, it's the second time it happened to me too. I park in a lot for work next to a construction site where they're building high rise condos.
    First time, a good detail and re-opti coated was able to help it, and they covered it quickly.
    Few months later, same thing, but 10X more cement sprayed on the car. Majority of the car had to be repainted, and still need to get it re-opticoated.
    Everything including the rental car eclipsed $10K+ in damages, car was in the shop almost 2 months.. a lot of back and forth on the blame game between construction company and cement company, and I got stuck in the middle. Now I have the challenge of my auto insurance carrier pursuing them for damage reimbursements so my premiums don't skyrocket on me.
    Some positives though, the car is better than brand new right now. Plus I was able to get the V6T badges replaced with the Supercharged badges, easily a gain of 10 hp I'm told.
