    Senior Member Two Rings Rock803's Avatar
    Aug 01 2014
    Orlando
    Stretch Bolts for suspension
    Hello all. I've been searching and I can't find which bolts and/or nuts need replacing when doing a suspension swap. Mostly I would like the part numbers if anyone can help. I know most say just reuse. But I don't want to get stuck with a snapped bolt. I'm able to do the swap myself, it's just these tty bolts are a pain.
    Thanks, Adam
    The Edge
    2015 A4 Florett Silver Metallic, Premium+, S Line, BO, 8sp tip, Sport, Sport+, Tech
    2012 A4 Brilliant Black, Premium, 6sp (sold)
    Senior Member Two Rings ECDT's Avatar
    Jul 15 2015
    Philadelphia
    Here is a list of all the parts supplied in ECS kit when installing a cup kit or coilovers.
    https://www.ecstuning.com/Audi-B8_A4....0T/ES2762762/
    You should be able to figure out from the list what you need and order individual fasteners or the whole kit.
    Aug 01 2014
    Orlando
    Thanks. I've seen that. But it's a little vague. It only shows front lower and rear upper/lower shock mounts. What about the front upper, pinch bolt, lca, etc for the front?
    The Edge
    Established Member Two Rings JesssMooo's Avatar
    Mar 31 2015
    ECS has a KW coilover install manual for B8 A4. In it you'll find which bolts they suggest replacing. Unfortunately the manual doesn't give part numbers so you'll have to do a bit of digging but at least you'll narrow your search. GL.
    2013 A5 | Prestige | Ibis White
    Aug 01 2014
    Orlando
    Thanks. Saw that as well.
    The Edge
