Results 1 to 3 of 3
    Veteran Member Three Rings rkern's Avatar
    Jul 26 2012
    93 Corrado VR6
    SoMD
    MAF or other Issue
    I was driving the car home yesterday and half way through the trip it started acting up. When I was accelerating from a stop sign, once I got to around 3k RPM's the car would bog and have no power when giving it gas. The ABS and ESP light came on when this happened but no CEL. I was able to drive it the last 3 miles home but had to keep it in low RPM's. I scanned it and had multiple codes. I cleared it and only 2 codes stayed on. One was for the MAF and the other for the ABS system. I don't have the codes with me here at work. The RPM's would flutter at idle and the boost gauge would read about 18 or 19 for vacuum. I unplugged the MAF and the idle acted normal and the vacuum went back to 21. I drove the car around to see if it was still stuttering under acceleration and it drove fine. I did notice that I had no boost. Trying to figure out if I have a bad MAF and other issues or just a bad MAF. I have a MAF on order. I'm a little new dealing with turbo cars, my experience has been with NA VR6's. Any help is appreciated. Thanks.
    Car is an 01 with an EPL Stage 2 tune.
    01.5 S4 Avant Imola Yellow Stg 3
    93 Corrado VR6 3.0L
    Established Member Two Rings verstappen's Avatar
    May 05 2014
    B5 S4, B6 S4, B8.5 A4, 11 Audi Q5
    Phoenix
    boost leak, most-likely.
    With your mind power, your determination, your instinct, and the experience as well, you can fly very high.
    -Ayrton Senna
    Jul 26 2012
    93 Corrado VR6
    SoMD
    Found a rip on the bottom of the TB boot where it connected to bi-pipe. Small but I guess enough.
    93 Corrado VR6 3.0L
