Results 1 to 7 of 7
    Established Member Two Rings q2quest's Avatar
    Jan 22 2009
    Santa Rosa, CA
    3.0 motor, what the heck is this hole?
    In the second photo at the tip of the screwdriver. I just discovered this. What the heck? It's a hole, but it doesn't appear to leak any oil.
    2018 A6 3.0T Competition Package, Daytona Gray, Jackal Motorsports Stage 2, 15mm wheel spacers
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    Deformity?? Not broke don't mess with it
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Senior Member Two Rings sinful7's Avatar
    Nov 19 2006
    1994 Schwinn
    Casting thing. My block is the same.
    Jan 22 2009
    Santa Rosa, CA
    Quote Originally Posted by sinful7 View Post
    Ok, thank you; glad to know. I thought I had a hole in my engine. You have no idea what a relief that is.
    Veteran Member Four Rings evo_ski's Avatar
    Mar 15 2010
    Bothell
    Its a speed hole.
    Costco 92 Octane Gas - MANN Air Filter - 235/35/19 Tires w/ 36 PSI (cold) Tire Pressure - Grey Plastic Valve Stem Caps - 0° Front Toe - Rotella T6 5W-40 - 2 OEM B6 Keys - 18x8" Spare - Coin & Pen Filled Center Console - Rain-X on all 8 windows & Napa Cold Temp Washer Fluid - Bosch Wiper Blades (Valeo wipers suck big time!) - S4 Trunk Latch - Craftsman Tire Pump w/ Automatic PSI Shutoff - Belly Pan Delete (Weight Savings) - 3D Printed Rear Warning Triangle latch - 174,000 Miles & Counting
    Aug 18 2014
    Plattsburgh, NY
    It's a normal casting mark on those blocks.
    Aug 26 2005
    Quote Originally Posted by q2quest View Post
    You do have a hole in your engine.
    Vorsprung durch Technik
