Results 1 to 11 of 11
Thread: AC help
    Veteran Member Three Rings Ray1031's Avatar
    Nov 01 2015
    San Antonio, TX
    AC help
    So on my way back from lunch AC just quit blowing cold air. It's 105 and not sure now what I can check...
    Aug 04 2015
    Kansas City
    It might be a bad pressure sensor or a leak somewhere. If it was I, I'd probably take it to an Audi/VW shop to have them scan it with the VAGCOM and see it there's a trouble code. If you do anything that accidentally evacuates the system or opens it to outside air you could end up spending more money than you expected.
    Nov 01 2015
    San Antonio, TX
    Just scanned and got codes about the engine mounts, battery, remote not working, nothing about the AC....
    00446 - battery
    00858 - radio antenna
    05634 - replace battery
    05495
    05491
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    When's the last time you replace the pollen filter? Check and see if it's clogged with buildup. I change them out every year or 15K to keep my climate control running in tip top condition.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Nov 01 2015
    San Antonio, TX
    AC help
    Quote Originally Posted by 80sGuy View Post
    It was replaced last November when I purchased it.
    I'm at a shop right now and they are telling me it needs a new compressor and an expansion valve, $1200, if I add the timing belt to it it's about $1,970.00 ....
    Veteran Member Four Rings DanKing's Avatar
    Aug 14 2014
    California
    Anyway to trouble shoot if it is the compressor? Surely you can hear it fire up ?
    I feel my ac is not powerful after about 30 mims of driving. When I fire it up it blast cold air, then after a while it's still cold but not as cold or powerful :-/
    '07 6MT Brilliant Red 2.0T
    JHM Stage 1 • JHM test pipe • ST coilovers • Smoothed Cupra R lip • Relak Skirts • 3sdm 0.06 • 034 mounts • Revo snub • GFB DV+ • S4 Recaro seats • RS4 Steering Wheel • Joey'd Bi-Xenons • Phils V4 LEDs • STI projectors • LEDs everywhere • APR Carbonio Intake • p3cars Gauge
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    Quote Originally Posted by DanKing View Post
    I thought our cars did that intentionally when the car is around the temperature you have the climate control set to? It definitely lowers the air output/fan speed when it comes to temp.
    2007 Porsche Cayman | 5MT
    Feb 15 2016
    Cambridge,Ontario
    I just don't trust these guys ...
    just stopped working and it happens to be a 2000 dollar fix ?
    id get a second opinion.
    Quote Originally Posted by Ray1031 View Post
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Aug 14 2014
    California
    Quote Originally Posted by Ashtonts View Post
    Mine was set to LO and max fan speed the whole way to LA (40 min drive), was around 102° outside and half way through the journey I started sweating :-/
    Veteran Member Three Rings 1killera4's Avatar
    Mar 18 2014
    Dunedin Florida
    I hope you at least get a kiss before that...
    Nov 01 2015
    San Antonio, TX
    Thanks.... I'm taking it to another place tomorrow
