Results 1 to 11 of 11
    Jul 13 2014
    1997BMWZ3
    Daly City,CA United States
    Engine pull and timing service time frame
    Let's say I have a whole week off and I have all the tools required. How long would it take for me to finish everything including a new clutch? This is my first engine pull btw. Reason why I'm asking is I rent my house from my uncle and he doesn't like it when I make a mess in his garage and he comes down to visit maybe once every month.
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    It took me 10ish days I think to go from pulling the garage to out of the garage. That was roughly 8-10 hour days I think? I had a guy help for a few hours at the beginning and end, on the actual pull and angling the motor back in, and my dad helped with an extra set of hands from engine+trans separation until they were re-united. I basically took one week off work and worked Friday night after work, through the next week, and still needed to take off that last Monday. However my family was visiting so there was one day we went to the city and didn't do much of any work.
    I hit some delays:
    - forgot a small o-ring on one tensioner, realized after I had the timing covers back on and trans bolted back on... killed a good day with that
    - broke the rear coolant hose, had to overnight one to finish putting motor back in
    - rear O2 sensors relocated, waited a day for those to get done
    I also did:
    - Valve cover gaskets
    - Mounts
    - Built a custom engine+trans stand (took a solid half day)
    - Valley pan service, so I had to get the IM, oil filter, etc off. Spent a day doing all that with all the cleaning it needed
    - Added trans cooler
    - piggied the downpipes
    - motor mounts
    - so. much. cleaning.
    It was also my first engine pull. I don't have many fancy tools or a big garage. If everything is smooth, you actually have all the parts/fluids, don't break any bolts, etc and you don't take off the IM or do too much extra, I bet it could be done in 4-5 long days for a first timer. Really depends how much stuff you are doing because the motor is out and you have easy access, how much cleaning you want/need to do, etc.
    If I had to do it again I would feel pretty confident getting it done in a week.
    edit: I've got a tip trans, so IDK how long the clutch would add. I think it's a little easier to pull the motor+trans with a tip, less subframe and you don't need to take apart anything inside the car, but I doubt that makes up for the amount of time you'd spend replacing the clutch. But I dunno
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Jul 13 2014
    1997BMWZ3
    Quote Originally Posted by badger. View Post
    I hit some delays:
    I also did:
    - Mounts
    - motor mounts
    Thanks for the reply. Since I have done piggies, oil check valve and other maintenance, the clutch and timing would be the only concern. I should able to finish it within a week if nothing breaks but im pretty sure i will run into some trouble. How did you label or remember which hose and wires goes to where?
    Senior Member Two Rings icanfly's Avatar
    Jan 12 2012
    06 B7 S4 | 92 Corrado SLC VR6 | STI Powered HandBuilt TarmacRallyCar | Skydiving Rig
    Looking for a canyon to carve.
    I'll mirror Badger. I did mine entirely solo, it was my first time pulling this motor and I broke an electronic tensioner unit putting it back together - I would say that if you pace yourself, give yourself breaks and go at a SLOW and steady pace, you should be able to start on a friday night, do the work over the week, finish up the following Sunday with your first start. There are a few absolutely critical moments that you don't rush. Don't get frustrated, take brakes, stay hydrated (beers only at the end of the day) and keep your bolt management ON LOCK (I can share my tricks if you need)!
    other than that, I did my work with an HF hoist, jack stands and some shit tires I had laying around to set the motor/trans on while I worked on it. I pulled solo, and reinstalled with a friend to help get the trans back under the car. I did everything you're doing plus a ton more so you should be able to do it. Read and Re-Read the motor pull DIY / Make sure you have all the tools (including timing tools). Make sure you have all clutch parts, including the slave Cyl before you get started. Be prepared to Overnight at least one or two parts.
    let me know if you want to jump on the phone and talk through the tricky parts. More than happy to support another member. I've also got timing tools if you want to rent.
    you can do it.
    slow is fast...
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    Painters tape is your friend for labeling wires and hoses. 1 goes with 1 and so on.
    Jul 13 2014
    1997BMWZ3
    Quote Originally Posted by icanfly View Post
    you can do it.
    Thanks man really appreciate your offer! I will call you when I'm in the middle of a sticky situation. Your post gave me a confident boost that I can tackle this alone
    Jul 13 2014
    1997BMWZ3
    Feel free to comment on this thread about your experience of the timing service alot of advices from other people will prepare me or anyone who is about to pull the plug
    Mar 31 2014
    KY
    - I used masking tape for electrical connections, tab of tape on each end, label it with same letter both ends, I just start labeling at "A" and go from there.
    - I also took a lot of pictures with my finger point various connections and routing paths for wires/cables as I went, I reference those quite a bit on the reassembly. That was helpful for the wiring harness and all those little plastic clips that snap into various brackets and whatnot.
    - I used those cheap clear plastic storage things from walmart or wherever to store the nuts/bolts/whatever. Look like this:
    - I used a dry erase marker on the lid, drew a grid corresponding to the spaces, and labeled it that way. Kinda looked like this but with a dry erase marker:
    - I've linked this thread a bunch but it has a lot of good info on it, I started it when I started my timing work and tried to update it as I went..
    Clicky!!
    - For stuff like main trans bolts to engine block and the gazillion bolts on the timing covers, I used a sharpie right on the block and numbered them in the torquing sequence (and wrote the corresponding # on the bolt head) for easy re-assembly.
    As icanyfly offered as well, feel free to PM or email me or whatever if you need anything, I've got a shitload of pictures and stuff I never posted in my thread.
    Aside from all the tools/equipment needed, I would recommend having:
    - a friend over for: helping guide the motor+trans out, helping separate them once they are out, and also for shoehorning it all back in (that was the hardest part lol).
    - Just a couple hours here and there with that extra set of hands will go a long way unless you've got a nice shop set up and lift and all that snazzy stuff ;)
    - Bentley manual. If you got one recently there is a web access code, I just brought my old laptop to the garage and sat it on the workbench. great for sequence of events and torque specs
    - the cuccaroocococ or whatever his name it engine pull guide. I printed it right off at work and went through page by page. It is very accurate and thorough. lots of copies/links to it floating around here
    Veteran Member Three Rings SprintBlueWorld's Avatar
    Sep 16 2013
    08 Hemi Big Horn, 08 Honda civic, 08 Audi S4 Cab MT6
    Pa
    Excellent practical resources. Kudos.
    Oem RS4 Reps, RS4 Pedals, KN Air Filter, JHM 93 tune, JHM Intake Spacers, Rear Stoptech Slots & SS Brake lines, JHM 6-Rib Pullys, 034 Snubby Bracket, Dimple/ECS Oil & Diff Magnetic Drain plugs, Apikol Diff Mount, 034 Carrier Mount Inserts, Corsa RSC Cat-Back, 034 Sway Bar & End Links, Piggies in a Blanket, Front JHM LW Rotors, Hawk HPS pads, 13mm Spacers
    Feb 18 2014
    Arizona
    Also, on removal I had an issue with the shifter not having enough clearance and rubbing against the heat shielding. There's a couple ways you can avoid that - One way is to remove the bolts holding the downpipes to the transmission before you start to pull the engine out (Joey doesn't mention this in his guide, maybe cuz he has headers, but you're gonna need to remove those bolts anyways once it's out). I hadn't done this and the downpipes contacted the subframe as the whole thing was coming out, which prevented the trans from dropping down far enough to get the shifter out. Removing those bolts will give your downpipes more room to flex and allow the trans to drop down some more. Another thing you can do is to remove one of the linkage rods holding the shifter to the transmission, that way you can swing the shifter farther out of the way and get more clearance above the transmission. If I was to do this job again, I might try and just leave the shifter connected to the car, and remove the linkages from the trans before pulling the engine out. That's what Jimmybones does before removing the trans in his clutch writeup on another site.
    Veteran Member Four Rings gcoy's Avatar
    Apr 06 2009
    2005 B6 S4 6mt Avant & 2001 B5 S4 6mt Avant (Sold) & 2007 VW Passat 3.6 4Mo wagon
    Boise Id
    Quote Originally Posted by 2004B6S4 View Post
    Great advice, I had the same prob
