Results 1 to 8 of 8
    Veteran Member Four Rings roboto_1337's Avatar
    Jul 05 2016
    B7 S4 6MT, Porsche 958.2
    Ontario, Canada
    O2 Sensor Spacers for B7 S4????
    Does the spacer need a restrictor orifice in it? or does a straight bore work? I'm thinking about using these... but if the orifice isn't needed there are much cheaper options...
    https://www.summitracing.com/int/par...1619/overview/
    Am I correct in that the spacer slows the velocity of the exhaust gases passing the sensor so it won't throw a CEL with piggies? (pre-cats only)
    Thanks
    Jul 13 2014
    1997BMWZ3
    Daly City,CA United States
    Do not space out the pre cats o2 sensors! I accidently did that and the engine was running super rich. Do it on the main cats sensor. You won't get CEL. I passed smog with just regular spacers
    Jul 05 2016
    Ontario, Canada
    Quote Originally Posted by kevinye77137 View Post
    Good to know... I wasn't planning on spacing the pre cat sensors, but it seems that some people have been confused by this.
    What spacer did you decide to go with, it looks like some of the fixed body type have smaller a orifice than others...
    Senior Member Three Rings scottkollig's Avatar
    Nov 12 2015
    Delray Beach, FL
    Being farther out, they allow the sensors to read that the exhaust is running at normal velocity. But they aren't guaranteed to work for everyone. IMHO, I wouldn't even waste your money on the spacers, though. You're better off going with the JHM tune to get rid of the CEL, plus you get a fantastic bump in hp and tq, launch assist, etc...
    The most dangerous phrase in your vocabulary is "good enough".
    DTM 08' S4
    Jul 05 2016
    Ontario, Canada
    Quote Originally Posted by scottkollig View Post
    August birthday... JHM tune is on the way, I just am figuring I'm going to have time to pull the DPs and gut the pre cats before I get the tune... want to have all the parts lined up ahead of time.
    Veteran Member Three Rings Aok303's Avatar
    Jul 12 2012
    Bicycle bicycle i want to ride my bicycle
    Lakewood-Morrison / Colorado
    so if you have piggy pipes, if you dont use a spacer on the pre would you get rich in both b1s1 and b2s1
    im trying to sort out an issues where im running rich. i do have piggys and the 91 tune from JHM
    weird enough i havent touched the pre and was not getting a check engine light now being 3 years later i cant track down my rich issue
    Jul 05 2016
    Ontario, Canada
    Quote Originally Posted by Aok303 View Post
    Hrm.... would it be worth re-locating the 2nd O2 sensor behind the main cat? (if you have a buddy with a welding machine)
    Jun 04 2015
    Southeastern MA
    I used ebay stainless steel spacers and they work just fine no engine light. http://www.ebay.com/itm/2X-O2-OXYGEN...ZW5-Ka&vxp=mtr
