Results 1 to 6 of 6
    Jul 01 2016
    Itasca, Illinois
    S4 badge on ECS grille
    Just another quick and easy way to mount the S4 badge on an RS4 grille. . First I made the two spaces on each side of the clip part larger. . Then use 5/8" heater hose and slide it on. It fits perfectly in the holes on the grill. Silicone in place and your done.
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    That's good to know. I just gave up w removing the badge from stock grille and am bagde less on the front w my ecs.
    Senior Member Four Rings
    May 20 2015
    Audi S5 Deep Sea Blue Pearl
    PA
    Well ill be a SOB lol. I pretty much gave up putting mine on my S5 since i forgot to add it on while the grille is off the car since its much easier. I did not want to glue mine on, so my badge has been sitting in the door side pocket for about a month and a half now lol. I would be ok with silicone since you can remove that. Although i have the USP motorsports version i assume its close to the ECS grille openings.
    Great idea by the way to snug it in nicely!
    Jul 01 2016
    Itasca, Illinois
    And this was done after the grill was already installed.
    Veteran Member Three Rings Avned's Avatar
    Apr 20 2016
    Las Vegas
    Ingenious! Wish I would've done this with my S6 badge. Mines hanging on with velcro and crazy glue. This looks much more stable.
    '22 RSQ8
    '13 S6 DS1 stage 4 flex fuel - SOLD
    Veteran Member Four Rings miztahsparklez's Avatar
    Dec 19 2010
    North CA
    I just cut up the rs4 badge and used that as a backing for the s4
