Results 1 to 40 of 51
    Veteran Member Three Rings Sour's Avatar
    Dec 08 2008
    B8.5 Brilliant S4
    Post Clutch failure Audi B8.5 S4
    Stock B8.5 S4 21k miles and the clutch has failed according to the dealership. I ask them if they have photos or inspected the clutch they said they looked at it through somewhere but didn't actually take it out. Car had no signs of slippage, no chatter, is stock, the car is never launched or driven hard and half of the miles are highway. The day it stopped working the only thing out of the ordinary was an intermittent brake symbol on my cluster that lasted maybe 10 minutes about an hour and a half prior to the pedal losing pressure.
    Of course the dealership wants a fist full of money and I'm not buying what they're saying.
    Really unimpressed with the whole situation. I'm going to call aoa and see what they say as well.
    Parts wise I did look at the ECS stage II kit they had up on their site southbend/flywheel, any other suggestions or websites to order from? Thanks
    Past
    00' S4 Stage III
    02' S4 Stage II
    95' UrS6 Avant
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    if it exhibiting no signs of failure get a 2nd opinion. \very very strange .
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    There was no slipping or chatter, so why were they even looking at the clutch?
    Dec 08 2008
    B8.5 Brilliant S4
    Quote Originally Posted by The Fat Kid View Post
    the clutch has no pressure
    Past
    00' S4 Stage III
    02' S4 Stage II
    95' UrS6 Avant
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    That makes no sense.
    Edit: I see now that there was at least some symptoms. Not sure what to say about the diagnosis but there are plenty of options. Eurocode, JHM, Southbend, stock OE, Sachs.
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    If the pedal lost pressure wouldn't that indicate a hydraulic problem? I would suspect the Master/Slave cylinders.
    Dec 08 2008
    B8.5 Brilliant S4
    Quote Originally Posted by jsh139 View Post
    At the time I felt it was an electronic issue or an issue with the pedal itself.
    Past
    00' S4 Stage III
    02' S4 Stage II
    95' UrS6 Avant
    Mar 10 2015
    New England
    Quote Originally Posted by Sour View Post
    I read it as the clutch died while at the dealer. Sorry, I am a little slow today
    Jan 10 2007
    VA
    Sounds like textbook clutch slave cylinder failure.
    Internal seals can leak allowing fluid to move without pressurizing the hydraulic system activating the clutch. The pedal has no resistance and there doesn't even need to be an external leak. This is a warranty item. It's not expensive ($150) and yes...is made out of plastic. https://www.ecstuning.com/b-genuine-...er/8k0721257a/
    My guess...either the dealer is ignorant and half-assed the diagnostic or they are trying to sell you a price-gouging full clutch replacement when you really don't need one.
    Get AoA involved.
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    makes sense that it is probably the master or slave that is bad and is leaking. The brake light came on cause you lost your fluid in the reservoir. I would get a second opinion on the issue, seems they are trying to rape you for a full clutch based on the symptoms.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    May 29 2012
    Evergreen, CO
    Wouldn't a B8.5 with 21k miles still be under warranty?
    Dec 08 2008
    B8.5 Brilliant S4
    Thanks for the input guys. Just let AoA know how I feel about the situation, they said two business days so I'm looking at Monday. Going to call dealer again and ask them for notes from the Tech and see if they checked the slave cylinder.
    We've owned at least 6 manual Audi over the last few years and each of them held up to at least 100k on the cutch. I'm hoping they step up and don't try and stiff me here.
    For reference the dealership wants $5500 for a clutch and labor, at $4900 with a discount.
    I did reach out to an independent shop here for a quote, just trying to figure out with tow, parts, and labor where I'll land.
    If I were to keep it I'd probably add a tune, pully, and exhaust so I'd want a clutch that can handle that if I go the indie shop route.
    Past
    00' S4 Stage III
    02' S4 Stage II
    95' UrS6 Avant
    Oct 14 2012
    Empty...for now...
    SE PA
    I'll echo everyone else and say that based on the symptoms you mentioned, this does not sound like a problem with the clutch itself. Any supporting parts of the hydraulic system definitely should be covered under warranty.
    SOLD 2015 Daytona Gray S4
    Jan 26 2015
    2017 XC90, a workbench
    CO
    Tell them to eat shit and die. You would have to be the worlds worst manual driver to wear out a clutch that quick, even on this car. But if you do replace the clutch, I am very happy with my jhm clutch on stock fw.
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    FYI, unless the dealer is going to give you some type of allowance on the clutch replacement, it makes no sense to allow them to do it. It is NOT covered under warranty. I would first replace the clutch slave cylinder. If that does not solve your problem, I would take it to an Indie garage to have them replace the clutch assembly. Audi will not install an aftermarket clutch in your car . Plus they will charge you twice as much to do it.
    Senior Member Two Rings ellwood's Avatar
    Feb 12 2015
    16 SQ5, 21 M340i
    PA
    The clutch can't be seen without dropping the transmission. There is an inspection port at the base of the bellhousing but you'd only be able to see the backside of the flywheel
    2021 M340i xDrive, 2016 Sepang SQ5, (sold) 2012 Glacier White S4 6MT - APR Stage II
    Dec 08 2008
    B8.5 Brilliant S4
    Quote Originally Posted by ellwood View Post
    The shop foreman said as much when I called and asked to speak to him. He said that he'll take a microfiber camera and look for cutch wear to give me a better idea. Also that it could be a cylinder or something else but they'd have no idea till the take everything apart and it could be warrantied item in the end or it might not be.
    Can they change the clutch slave cylinder without dropping the transmission right?
    That said I wonder what the first diagnosis charge was for and what the quote was about?
    Past
    00' S4 Stage III
    02' S4 Stage II
    95' UrS6 Avant
    Apr 04 2012
    MSP
    Quote Originally Posted by infinkc View Post
    Quote Originally Posted by b6onboost View Post
    Get AoA involved.
    I echo this.
    If you had a brake warning light then it makes even more sense.
    Nov 12 2015
    Here
    That's way too high, even if they are including a new flywheel, which you definitely don't need at 20k. List/book should be closer to $3200 for doing the clutch alone. And they have plenty of room to come down from there. A good tech can do a clutch in 8-9 hours. Book has it at 12. Good luck.
    Mein ist grau
    Feb 12 2015
    16 SQ5, 21 M340i
    PA
    The slave can be changed easily since it's just bolted to the side of the transmission. Even with a small camera, the clutch friciton disk is sandwiched between the flywheel and the pressure plate so you can't see it. Check out the install instructions for the ECS tuning lightweight flywheel on their website, the PDF shows detailed pics of the entire clutch module
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    By "clutch failure" , you mean the clutch pedal has no resistance...or stays on the floor when depressed?
    Your symptoms clearly indicate a failed master cylinder, or the slave cylinder. Both are relatively easy replacements, that don't require the transmission removal....(sounds like your dealer is aiming to rip-you-off, with an unneeded full clutch-job......run away.)
    There is really nothing you can see in the "Inspection Port" on the bell-housing. It is only there to have wrench access to loosen the bolts that hold the pressure plate to the drive plate.
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by S4'ed View Post
    I agree it doesn't sound like a clutch failure, but shouldn't the master and/or slave cylinder be covered under warranty? Sure it's a supporting component of the clutch function, but it's not something that the user can "abuse" like the clutch itself or brake pads/rotors.
    Sep 24 2014
    Central NJ
    The Slave and Master Cyl should be covered under warrantee : they are not "Wear Items" (Clutch disc, pressure plate, brake pads, brake discs, tires).
    Jan 10 2007
    VA
    Get AoA involved.
    If the dealer 'has no idea' what the root of the problem is, whether it will be warrantied or not, why are they pushing a $5k clutch replacement? Why are they charging you diagnostic fees?
    Your car is under warranty. Your clutch didn't wear out, it randomly failed, and flashed a brake light. They should investigate the issue(s) and once they know what it is tell you if the replacement is warrantied or not. This is on them to figure out. If it does turn out to actually be the clutch, push AoA hard for a goodwill replacement. As you've stated, you've owned 6 Manual Audis and none of their clutches failed prior to 100k...this one (may have) at 21k...which is absurd.
    May 17 2012
    Houston, TX
    I'm gonna say dealer f'd it up during a "test drive" that they did not need to go on.
    Dec 08 2008
    B8.5 Brilliant S4
    Get AoA involved.
    I called AOA on Wednesday and have called them again today.
    It makes no sense to me. They clearly didn't diagnose anything the first time all they did was generate a quote and bill me.
    I called dealership again today and I feel that I got the run around again today. I can tell they don't want to deal with me.
    The car is under warranty idk why they're charging/trying to charge me for diagnostics that in at least one case wasn't even done. I agree with you completely. That's what I'm pushing AOA to do.
    Also Audi roadside left me stranded for 3 hours when this originally occurred and it was due to their errors. First time they didn't dispatch a tow, then tow dispatched to the wrong location twice, another tow truck supposedly broke down.
    Past
    00' S4 Stage III
    02' S4 Stage II
    95' UrS6 Avant
    Senior Member Two Rings JustPlaneChris's Avatar
    Jun 09 2016
    1998 Mazda B4000
    Austin, TX
    ...tow truck supposedly broke down.
    Maybe it had an S4 clutch in it.
    All jokes aside, I hope you get this taken care of. It makes me nervous about my car!
    Chris
    2014 S4 - 6MT | Brilliant Black | Black Optic | Carbon inlays | Alcantara | B&O | CR-15 Strut Brace | 034 Intake Hose + K&N
    Dec 08 2008
    B8.5 Brilliant S4
    Dealership is saying the cylinder is fully extended and they see springs fully extended on clutch/pressure plat, therefore the clutch is done and replacing cylinder won't fix anything.
    Dealer said to talk to AoA about goodwill as it exceeds amount they will cover.
    AoA said wait another two business days now. AoA trying to say it's wear and tear item and that's it but give them more time. Going into a full week without a resolution now.
    I'll let you guys know what happens in the end. All I've had are people reading off of a script to me so far.
    From the looks of things I guess my brand loyalty hasn't been worth much, well at least obviously not defective clutch on the 50k+ car I've bought new. Wow.
    Past
    00' S4 Stage III
    02' S4 Stage II
    95' UrS6 Avant
    Jan 26 2015
    CO
    I feel for you man. Really, that sucks. Try bringing up your past Audi's and say your brand loyalty is waning because a clutch should not go out on an audi with 21k miles. Drop a hint that the bmw 4 series doesn't seem to have clutch issues and maybe you will look into one in the future. but if they really won't cover it, just upgrade the clutch.
    Jan 15 2012
    2016 explorer sport
    Sacramento CA.
    Dude, I had my clutch replaced at 17k. Audi paid half. I'm no pro at driving and may have burnt the clutch several times but I couldn't believe it needed to be replaced. There were no previous signs before. It just started slipping every time I would try to quickly throttle in 1-4. I've read so many problems with the clutch then I read the pros who get 100k out a clutch and I'm like WTF. I'm curious to see a poll of how many people have had prolems with their clutch. The system isn't a traditional clutch changed I believe in 2012.. I've read that in stop in go you can burn the clutch super quick. I guess in first your not supposed to throttle the gas at all and just let the clutch auto rev and engage. When in traffic I've altered my driving technique to this...
    Dec 08 2008
    B8.5 Brilliant S4
    They've now offered to pay half. I still feel that is not enough. Will update later today.
    Past
    00' S4 Stage III
    02' S4 Stage II
    95' UrS6 Avant
    Nov 12 2015
    Here
    Quote Originally Posted by dansjuice View Post
    You read this where?
    I've read that the Chupacabra comes in the night and eats goats and small children. I've now taken to locking my goats and small children in the barn at night.
    Mein ist grau
    Senior Member Three Rings Victor Newman's Avatar
    Oct 26 2014
    NC
    Similar story here. Had my clutch pedal intermittently go "sticky." It would never stay at the floor or anything, but coming back up, it would be so slow sometimes. I could pump the pedal rigorously and it would free up just fine, and every once in a while, it would get sticky again. Took it to the dealer and they said I needed a new throw-out bearing. They replaced it under warranty, pulling the trans out, and there was no change whatsoever. Took it back in with the same problem, and they said you need a new clutch - it's worn out, and gave me a quote for about $4K. I told them no thanks.
    That was about 15,000 miles ago and I've got no clutch slip giving it full throttle in 4th gear at 70mph on the highway (a quick and dirty little test an engine building buddy of mine told me to try - simulating maximum engine torque and maximum resistance through poor gear selection). Every time it goes sticky, I just pump it rigorously a few times, and I'm good to go for a few more days. The Audi dealer told me it was the pressure plate springs worn out, but didn't have an explanation of how I could "pump" life back into the springs with the clutch pedal if the springs are worn out. I'm no mechanic, but I'm not sure some of the Audi service departments know what they're doing either, so they just throw out "you need a new clutch" and hope you just say OK.
    2010 S4 / 6MSG / Sport Diff / Alcantara Interior / StopTech 380mm BBK / Hawk HP+ / Castrol SRF / SRP Pedals / H&R Super Sport / VMR V710
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    Quote Originally Posted by Victor Newman View Post
    I've had the same experience and it still happens to this day. The classic mushy pedal feel and the return from the floor is slow. Pump it a few times and i'm good to go. It almost feels like i'm bleeding something and removing air from the lines when i sit and pump the pedal..
    I figure i'll just drive like it is until the car stops moving forward. Clutch seems to grab fine and does not slip. Just about to hit 63k.
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Jul 05 2015
    Lower Hudson Valley
    Quote Originally Posted by SportVier View Post
    It's not nice to lock your children up in the barn.
    Jun 09 2016
    1998 Mazda B4000
    Austin, TX
    Quote Originally Posted by jlaudio View Post
    I wonder if this behavior could be related to the pressure valve that is discussed in this thread?
    http://www.audizine.com/forum/showth...all-6MT-owners
    Chris
    Oct 26 2014
    NC
    yep, over 78,000 miles here. do you have the aftermarket line that deletes the delay valve? juat curious, as i was thinking about doing this anyway to improve feel, but would like to know if this definitely isn't the problem so i can check out other possible causes while i'm poking around
    Oct 26 2014
    NC
    Quote Originally Posted by JustPlaneChris View Post
    that's what i was thinking
    Mar 26 2009
    SLC, UT
    i don't have it yet but i have been following that thread and the technical discussion thread on the clutch replacement issues for months and have suspected that valve could be the issue. i don't have the time or access to a garage to install the line and from quoted times its expensive for the swap. around $500.
    i would really like to solve the issue because i feel like my clutch is all over the place on 1-2 shifting and engagement
    '21 SQ5
    May 31 2014
    Alabama
    What did the dealer end up doing?
    *SOLD* 2014 S4 | Glacier White | Premium + | DSG | 034 Drivetrain Mounts | ECS Slotted Rotors/StopTech Pads | IE Intake |
