Car (2014 3.0 TFSI) has been running rough and lean at idle with a small number of random misfires every drive... I've replaced the spark plugs, ignition coils and fuel pump & filter (and tested for vacuum leaks) but had no effect on the misfires... EDIT: cars max boost is 15-15.5 psi with the CTS Turbo pulley
I've been told it could be anything from o2 sensors, carbonization (car has done 20k km), clogged injectors, clogged catalytic converter, dirty MAP sensors, leaking intercooler... couple of VCDS outputs below... anyone had any experience with this?
going to cost a bit to look into every one of these so any advice or previous experience would be great!
