Results 1 to 4 of 4
    Veteran Member Three Rings Osher67's Avatar
    Nov 03 2012
    California/so cal
    Question Power steering flow question
    Dose anyone know which Way power steering fluid flows to the cooler?
    Is it from the reservoir to the cooler to the rack or rack to cooler to reservoir ?
    I'm installing a cooler and want to make sure I have the lines hooked up correctly.
    Thanks
    -Josh
    2002 01A Quattro
    K04-15 (Unitronic)
    Jun 09 2016
    Here's a diagram showing what looks to be the cooler after the rack: http://www.jimellisaudiparts.com/sho...driveLine=8046
    Hope that helps.
    Aug 26 2005
    It is not crucial for the direction of flow through the fluid cooler, flow from bottom to top is preferred.
    Flow is rack to cooler to reservoir. Upward flow through the cooler helps air purge.
    Vorsprung durch Technik
    Nov 03 2012
    California/so cal
    Thank you for replies and just thinking it over I redid the lines in an as you see in picture.
    But the BOTTEM line is from reservoir (blue)and top is from rack (red).
    due to the positions and style of clamp on the one on the bottom (blue) , it's not very easily replaced, and is a little short for top may just leave them be
    The cooler is more then sufficient.
    -Josh
    2002 01A Quattro
    K04-15 (Unitronic)
