Results 1 to 9 of 9
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Torque spec for transmission pan bolts
    Anyone know the torque spec on the dsg Trans bolts? Just buttoned up and need to lock it down...can't find it anywhere.
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    tight. Just use experience and common sense. If you know how to wrench then you will know how tight to make it. Not trying to be a dick but if you been wrenching for awhile you will understand. I only tq internal drivetrain components and lug nuts only.
    Jul 12 2013
    8V S3 and B5 S4
    Old Bethpage, NY
    To each their own but i'm with "BlownOne" on torquing. I've been wrenching for about 15 years, built motors, installed LSDs, etc. but I still torque everything down to my oil filter housing and oil drain plug on my S4. When i used to be a Metrology engineer i used to calibrate my torque wrenches at work with the torque measuring standard, it could be some form OCD.
    While some people feel comfortable by feel, some people, even the most experienced individuals torque every fastener.
    I'd like to know the trans bolts torque spec myself.
    2018 Carrara White Audi Q7 3.0T P+, Cold weather package, Vision package, Warm weather package, Driver Assistance package and towing package
    Stock
    2016 Mythos Black Audi S3 P+, Black Optics Package, Tech Package, LED Lighting Package, B&O, Red Calipers
    Modded
    2001.5 Brilliant Black Audi S4 Sedan 6MT
    Stage 3
    Dec 30 2015
    Sacramento, Ca
    I've been wrenching since I was in the womb brotha, but I like to KNOW 100% for sure I'm not going to get a leak when it comes to sealing fluids. There seems to be a lack of information on a lot of our drivetrain maintenance, so I'm trying to make it crystal clear for everybody.
    Will
    Jul 12 2013
    8V S3 and B5 S4
    Old Bethpage, NY
    Hey Will, did you replace the drivetrain stabilizer bolts with new stretch bolts? Also, you went with OEM fluid I'm assuming? Jjones tried out the redline DCT fluid on his last DSG fluid change and he seemed to like it. I was debating if I should try that fluid also or stick to the OEM stuff.
    Stock
    Modded
    Stage 3
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by cW6mT mKviGLi View Post
    Hey brotha, no I'm not replacing the X-brace's stretch bolts...I just add red loctite and tighten them back up. If they were head bolts I would for sure (unless I had arp hardware), but they are just holding a piece of aluminum to our car. Fwiw, when I removed them for the second time (already changed to ak brace) they were still crazy tight just like I left them.
    Yes I spent the extra cash to use oem fluid because it's too expensive of a part to try and save $100 on...plus you only do the service every 40k so it's really a small investment in longevity of the trans. I will be changing my dsg fluid every 15-20k miles since ill be making a lot more power than stock.
    I will be adding the torque specs for the transmission pan bolt this afternoon. Cheers!🍺
    Jan 14 2009
    pasadena md
    Quote Originally Posted by BlownOne View Post
    Will
    I feel ya. I usually never have issues with tightening a pan with a gasket or sealant and leaking shortly down the road. but if it was 2 machined surfaces I would tq no room for error. to each their own, there are probably tq spec for interior trim bolts too.
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    10 Nm
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Dec 30 2015
    Sacramento, Ca
    Thank for the info jran! I posted it in my other thread also, but I appreciate it man😎
