Results 41 to 80 of 106
  1. #41
    Stage 2 Banner Advertiser Four Rings deAutoLED.com's Avatar
    Feb 13 2015
    US
    Thanks for the support everyone!
    We have weekend support - we know you install our LEDs on the weekend and are here to help all weekend!
    Thank you
    www.deAutoLED.com
    //True Lifetime Warranty
    //FREE Shipping within the US
    //Tested error free LEDs for your Audi
    //Customer Support
    deAutoLED.com
    Facebook.com/deAutoKey
    Instagram.com/deAutoLED
    Lifetime Warranty & Support | Free Shipping within the US | LEDs Tested to work and look good in your car | Customer Service is our #1 Priority - We care what you install in your car!
  2. #42
    Feb 13 2015
    US
    Fog LEDs - bright error free:
    http://deautokey.com/product/led-hea...ast-1800-lumen
    Much brighter vs philips LEDs shown here - this is with yellow lamin-x on the lens:
    Matches OEM Housing that are white / creates wide spread of light past headlights / takes over in fog shining more light down road:
    Our LEDs are a clean white so when you place yellow film over it you will see a bright hyper-yellow light vs green.
    No errors
    No Radio Interference
    ​​​​​​​Light shines past your headlights and to the sides
    Plug & Play
    BRIGHT
    -True Lifetime Warranty & FREE Shipping!
    deAutoLED.com
  3. #43
    Feb 13 2015
    US
    Thanks for the support - email us at anytime if you need any help finding the right LED for your car:
    [email protected]
    deAutoLED.com
  4. #44
    Feb 13 2015
    US
    Don't forget to check out our plug and play Trunk LED strip
    -48 bright white LEDs (also available in red on drop down)
    -includes all adapters - simply plug it into your OEM housing and run the 48 LEDs anywhere in your trunk
    It is that simple - LISTING:
    http://deautokey.com/product/univers...all-car-models
    Fits all Car model:
    deAutoLED.com
  5. #45
    Feb 13 2015
    US
    -bright
    -error free
    -guaranteed
    -free shipping
    -plug and play
    -lifetime warranty
    -the list never ends :)
    deAutoLED.com
  6. #46
    Feb 13 2015
    US
    email 24/7 for help: [email protected]
    deAutoLED.com
  7. #47
    Feb 13 2015
    US
    White/Yellow/Halogen/Strobe/Flash plug and play fogs:
    http://deautokey.com/product/dual-co...low-at-anytime
    We now have 2 models:
    option 1: White/Yellow/Halogen/Strobe/flash
    option 2: White/Yellow/Halogen WITHOUT strobe & flash
    -Plug and play
    -Error free in most cars. Some might need extra resistance - we sell a new design that DOES NOT require you to attach it to metal. It is compact and easy to install - simply plug into OEM adapter and our LEDs (100% plug and play NO splicing design)
    -Easy to switch between each color – simply turn OEM fog switch off/on - normal cycle: White - yellow - halogen - flash/strobe
    -BRIGHT – this is not just a novelty bulb
    -COLOR MATCH - these match our LEDs/HIDs in 5500K White mode
    -HYPER YELLOW - these are a true hyper yellow mode you normally see with yellow lamin-x covering the lens **this is NOT a cover around a bulb or a cover on your lens - this is brand new LEDs that are a super hyper 3K yellow**
    -SAFE – more light on the sides and down the road when dark or in bad weather conditions
    -The Hyper Strobe / Flash – this does not simply "flash" but has a strobe/flash pattern like an emergency vehicle - you can choose between 4 different modes - video of mode 1:
    https://www.instagram.com/p/Bpjxc_ajyaS/
    3 colors:
    -Super Hyper 3000K Yellow that many like for bad weather: Rain, snow, fog
    -Clean White 5500k that matches our LED & HID Headlights
    -Halogen 4300k that matches OEM
    Video cycling quickly through colors AND different strobe/flash features:
    INFO:
    -THESE ARE BRIGHT! You might have seen the novelty fog LEDs that can turn yellow/white on amazon and ebay by the thousand that don't provide much useful light, trigger errors, die quickly, or simply don't work correctly. Our new model fixes every issue you might've seen and simply works.
    -These produce MORE LUMENS than many standalone single color white fog LEDs on the market
    -Not only are these great for safety, daily use on dark roads and bad weather this will amaze at any car show and you will have your friend asking how did you do that and where can I get those anytime you use these fogs!
    *Please note these ARE error free but in strobe/flash mode they can trigger an error in some car models – errors WILL clear once you go back to a solid color.
    UPDATED FAQ
    Is there a lifetime warranty?
    YES! As always this comes with a True Lifetime Warranty!
    Will your fogs keep changing colors if you use them as cornering lights?
    The answer is no as this only changes by turning your fog switch on/off. If you are using your fogs as cornering lights it will always be the default color of white.
    How does this work with the coming home feature?
    This works just like OEM. It will always be the default color of white.
    What if I have the yellow feature on and turn off my car; will it then go into the next color when I turn it back on?
    The LEDs will always revert back to the default color of white. Then simply turn the fog on/off for your desired color: yellow/halogen or strobe/flash mode.
    Can these turn 360 degrees?
    Yes, these are a fully adjustable design so you can turn these 360 for the best beam angle.
    Are these as bright as your single color de360 fogs?
    While not as bright lumen wise it comes very close - many people that have switched to our single color white to our dual color yellow/white LED fog kit have not noticed any difference in visibility. As we said this is NOT a novelty yellow/white you normally see. This is meant to be used to help with your visibility.
    Can you bypass the strobe feature?
    Yes, this works when you turn the fogs on/off quickly. If your next mode will be strobe simply shut off the fogs for a few seconds and then turn it back on and it will go back to the default white.
    Some more fun shots - in the rain:
    White / the super hyper yellow - this will be a hyper lamin-x yellow without the cover!
    And switch back to clean white:
    deAutoLED.com
  8. #48
    Feb 13 2015
    US
    Quote Originally Posted by comingabriel View Post
    How it looks installed (nighttime video)
    Get your footwells:
    http://deautokey.com/footwell-led-di...ll-audi-models
    deAutoLED.com
  9. #49
    Feb 13 2015
    US
    What is your fog LED preference?
    We have a LED for everyone.
    Solid Yellow [ Product Link ]
    Solid White [ Product Link ]
    White/Yellow/Halogen with Strobe & Flash [ Product Link ]
    White/Yellow/Halogen without Strobe & Flash [ Product Link ]
    With 4 brand new bright models you cannot go wrong.
    Note – all LEDs are in the same brightness range so you will not sacrifice brightness if choose one over the other.
    -Endless positive feedback and our guarantee has you covered so you can purchase with confidence
    -Large spread of light on the road for better coverage and visibility
    -These will shine bright on the sides of the road past your main headlights
    *Backed by our famous True Lifetime Warranty
    *Free UPGRADED shipping within the US (YES FREE)
    deAutoLED.com
  10. #50
    Feb 13 2015
    US
    These are bright
    no resistors
    no errors
    In stock and ready to ship
    for 2009-2017:
    http://deautokey.com/product/921-err...i-q7-2009-2017
    2018+:
    http://deautokey.com/product/921-err...r-2018-audi-q7
    deAutoLED.com
  11. #51
    Feb 13 2015
    US
    Choose your Fog LEDs
    Just yellow Fogs
    Just White Fogs
    White/yellow with or without strobe:
    -ALL you need to know is your bulb type - choose what style you want on this page and then choose the bulb type on drop down menu:
    http://deautokey.com/fog-leds
    deAutoLED.com
  12. #52
    Feb 13 2015
    US
    Orders ship same/next day with a tracking # from the US!
    24/7 Customer Service: [email protected]
    LEDs tested for your Audi
    www.deAutoLED.com
    Custom interior LED kits for all audi models. With puddle/footwells:
    deAutoLED.com
  13. #53
    Feb 13 2015
    US
    Find out why we are the go to place!
    LEDs for your Audi: Front turns, Low Beam, Fogs, Interior, Reverse and everything else - we have custom LED kits you cannot find anywhere all plug and play error free.
    If you cannot find what you need on our website: www.deAutoLED.com - simply email [email protected] for instant help - we have 24/7 customer service and ship daily from the US.
    We know many might've had bad experiences with other LEDs and many emails start with "This LED had this issue will your product have the same problems" - the answer is NO - our LEDs are tested in your model to work and look good.
    Some examples:
    -Error free front turns that are bright and can be seen in direct sun light
    -Low beam d3s HID that are bright and clean white that match other LED DRLs
    -Fog LEDs that shine wide on road and help and are not a novelty
    -Error free plug and play reverse LEDs you cannot find anywhere else that are very bright
    -Interior LEDs that are all different style bulbs - we don't just throw 20 194 wedges that look the same like some kits. Each one is designed around your housing
    -We customize our LEDs to work with the Audi electronics and why ours are sometimes the only ones that work - working is 1 thing but we then also make sure they are bright and something you want to use.
    Thank you
    deAutoLED.com
  14. #54
    Feb 13 2015
    US
    Perfect LED installing weather:
    www.deAutoLED.com
    deAutoLED.com
  15. #55
    Feb 13 2015
    US
    Did we mention it is the perfect weather for installing LEDS!!
    www.deAutoLED.com
    deAutoLED.com
  16. #56
    Feb 13 2015
    US
    Are you ready for Halloween, Fall and the winter?
    Get ready with Orange footwells
    Perfect Fall weather to install LEDs for the darker winter nights
    www.deAutoLED.com
    deAutoLED.com
  17. #57
    Feb 13 2015
    US
    Thank you for your service!
    deAutoLED.com
  18. #58
    Feb 13 2015
    US
    NEW YEAR NEW CAR UPDATES
    LEDs are going to be used everyday for the life if your car - these are tested to work and look good. DO not miss out:
    www.deAutoLED.com
    deAutoLED.com
  19. #59
    Feb 13 2015
    US
    See what you have been missing!*
    quick shipping
    LEDs that simply work with your car and are bright!
    ​​​​​​​www.deAutoLED.com
    deAutoLED.com
  20. #60
    Feb 13 2015
    US
    See what you have been missing: Quicker LED light-up time - faster reaction time. BRIGHT dark amber that can be seen in direct sun light.
    -NO ERRORS
    -NO HYPERFLASHING
    -PLUG AND PLAY
    Due to variations it is best to look up what bulb you have either by:
    -Looking in your owner’s manual
    -You can find this info on a stamp or sticker inside your car's engine bay
    -Looking at the model on the bulb itself
    -Bulb guide:
    Bulb/LED Guide & Help | deAutoKey
    Check them out!
    PWY24W:
    New Amber or White PWY24W Front Turn Siganls Error Free Bright Fits: Most Audi Models | deAutoKey
    H16/PSY24W
    Front Turn Signals H16 PSY24W Error Free fits: Most Audi Models | deAutoKey
    PH24WY
    New Front Turn Signals PHY24W Error Free fits: Most Audi Models | deAutoKey
    bau15s:
    NEW Rear Turn Signal OSRAM 3 Tower LED Bulb Fits: Volkswagen 08 Touareg | deAutoKey
    deAutoLED.com
  21. #61
    Feb 13 2015
    US
    Lightbulb
    LEDs are a great way to upgrade your car! Your stimulus check can upgrade your Audi to ALL LEDs twice!
    Email Us for bigger discounts when upgrading your entire car with LEDs: [email protected] - we have helped many get the perfect setup with a discount!
    ​​​​​​​Thank You
    deAutoLED.com
  22. #62
    Feb 13 2015
    US
    Shipping Daily!
    www.deAutoLED.com
    deAutoLED.com
  23. #63
    Feb 13 2015
    US
    check for sales at
    www.deAutoLED.com
    ->top of banner has all updated sales!
    deAutoLED.com
  24. #64
    Feb 13 2015
    US
    Thanks for the support and seeing the difference!
    Our LEDs simply work in your Audi - we are here 24/7 to help: [email protected] & ship orders daily :)
    www.deAutoLED.com
    deAutoLED.com
  25. #65
    Feb 13 2015
    US
    Happy 4th of July - codes on our website banner:
    www.deAutoLED.com
    deAutoLED.com
  26. #66
    Feb 13 2015
    US
    Join our facebook group for future discounts & deals exclusive to our FB Group members:
    https://www.facebook.com/groups/deAutoLED/
    deAutoLED.com
  27. #67
    Feb 13 2015
    US
    Check out fall sale going on now:
    www.deAutoLED.com
    deAutoLED.com
  28. #68
    Feb 13 2015
    US
    Check out sales at deAutoLED BANNER ON OUR WEBSITE:
    www.deAutoLED.com
    New sales are active until end of year (all will be listed on our website's banner) DO NOT MISS OUT!
    deAutoLED.com
  29. #69
    Feb 13 2015
    US
    LEDs that simply work - true Lifetime WARRANTY - FREE SHIPPING:
    www.deAutoLED.com
    deAutoLED.com
  30. #70
    Feb 13 2015
    US
    Bright Fogs.
    [URL unfurl="true"]https://deautokey.com/fog-leds[/URL]
    deAutoLED.com
  31. #71
    Feb 13 2015
    US
    LISTING:
    https://deautokey.com/product/dual-c...low-at-anytime
    Dual fog switchbacks - demo video:
    deAutoLED.com
  32. #72
    Feb 13 2015
    US
    See the difference.
    www.deAutoLED.com
    We see feedback like this almost daily. We take pride in offering lighting our customers will enjoy in their car daily:
    deAutoLED.com
  33. #73
    Feb 13 2015
    US
    Listing:
    https://deautokey.com/product/univer...all-car-models
    Perfect to light up a dark trunk due to the housing being in a bad spot in your car
    We thought of everything with our plug and play trunk strip.
    -OEM adapters including making this a direct plug and play adapter into your OEM housing (Easy install)
    -48 Very BRIGHT LED Diodes*
    -Clean White or red color option available
    -Flexible & bendable with hard resin coating so it can still take a beating in your trunk
    -Can place anywhere (top, bottom or side of trunk)
    -Long wire, that is an all stealthy black which allows for an easier clean install, this wire is long enough to place anywhere in your trunk
    Customer feedback:
    "No more dark trunk. I can see everything in my trunk now"
    "Love this. It lights up the ground when I open my trunk that someone actually stopped and asked me about the light after I opened my trunk"
    "I tried other strips and so far this is the brightest and easiest install as there was no adapters to solder or tap into wires. Their plug and play adapter makes the difference"
    "Clean light that is bright and exactly what I wanted"
    deAutoLED.com
  34. #74
    Feb 13 2015
    US
    Customer LED FOG Video:
    deAutoLED.com
  35. #75
    Feb 13 2015
    US
    Shipping daily - LEDs made for your Audi!
    -Buy with confidence
    -no more guessing if your LEDs will work
    -Bright and look OEM
    -True Lifetime Warranty (many companies offer 1 or 2 year warranties leaving you buying LEDs - never worry about buying another LED when you purchase ours)
    www.deAutoLED.com
    Check out our Fog LED line-up: White, just yellow or dual white/yellow fogs:
    These are brighter than most on the market.
    "I have the dual white/yellow w/flash option.
    Very happy for three years now a great value, in the high contrast use seeing obstacles "softroading"...plus snow, plus the white extra light into ditches in deer season.."
    deAutoLED.com
  36. #76
    Feb 13 2015
    US
    Lightbulb
    https://www.deautoled.com/ - sale on website banner
    -Error Free
    -Bright
    -Simply works in your Audi
    -24/7 Support - [email protected]
    ​​​​​​​We can help you find the right LEDs for your Audi.
    deAutoLED.com
  37. #77
    Feb 13 2015
    US
    Labor Day Sale ON NOW!! Check out website's banner for the deal of the year:
    www.deAutoLED.com
    -Error Free
    -Bright diodes
    -Thin PCB board for clean light output
    -True Lifetime Warranty (Leading warranty in the industry). This is truly the last LED you will have to buy for your car.
    -FREE Shipping within the US
    -24/7 support. Our team will reply with any questions almost instantly:
    https://deautokey.com/contact
    Compared to many top competitors are pricing are less and our diodes are brighter.
    Stop guessing what will work and do it right the first time. Our feedback consistently shows where other LEDs caused errors & were dim ours were error free & bright.
    We are here to make sure you get the product you want that works in your VW/Audi (and many more car models).
    deAutoLED.com
  38. #78
    Feb 13 2015
    US
    www.deAutoLED.com
    -Error Free
    -Bright diodes
    Bright fog LEDs where you want light - in white, yellow or dual fogs white/yellow:
    deAutoLED.com
  39. #79
    Feb 13 2015
    US
    Checkout www.deAutoLED.com ​for extended sale - limited time - hurry!
    deAutoLED.com
  40. #80
    Feb 13 2015
    US
    Choose your style of fog:
    deAutoLED.com
