Results 1 to 3 of 3
    May 22 2012
    FAIRBANKS/AK/USA
    torque requirement on camshaft retainer bolts
    OK, I searched the threads and found nothing.
    My Bentley manual does not call the torque out but the Haines manual I have does and I am wanting to check it.
    84 in*lbs or 7 ft*lbs seems light.
    is this correct?
    Jan 06 2009
    It is 10Nm according to AllDataDIY.com for the 1.8t
    This should be correct since it matches the 2.7t which for sure is 10Nm.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Yep 10 Nm which is a touch over 7 ft-lbs (88.5 inch-lbs).
    I just got done pulling and re-installing the cams in my 1.8T (CCT gasket/seal, front cam seals, replaced CCT chain guide pads).
    When you're removing those bolts, it's a bit misleading on the torque. I had to use vice grip pliers on every intake-side cam cap bolt! And one of the exhaust-side bolts broke my Lisle T30 Torx socket...
    2011 Audi A4 Avant Prestige S-Line
    2001 Corvette (C5) Z06
