Results 1 to 6 of 6
    Sep 03 2015
    South Dakota
    A/C recharge trouble (damaged condensor or discharge hose?)
    A year ago I recharged my A/C system after disconnecting the bumper for timing belt service. Everything was going normal until I heard a bang. I decided to look at it today because it's pretty hot out and I needed to fix a reflector that popped out of the bumper. So, it looks like the bottom hose popped off the driver side of the condenser during the recharge and that might have caused the bang. I'm pretty sure I screwed it together, and the screw is missing. Another concern - on the metal pipe on the driver side where it connects to the A/C sensor (I think that's what it is), there looks like there is some sediment. Does that indicate a leak? How can I reconnect the hose? Looks like I need a screw.
    Feb 24 2004
    Minneapolis
    Not sure what the sediment is. But after having that system open for a year, I would not just put it back together and recharge it. That system is full of moisture at this point, and the receiver/dryer is saturated. If you want your compressor to last for a few years, you need to have the entire system vacuumed out and have the proper amount of R134a put back in.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Sep 03 2015
    South Dakota
    Thanks. What kind of bolt do I need for that A/C hose that disconnected? Also, should I replace the dryer before or after vacuuming?
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    !. repair hose. 2. install new dryer. 3. Immediately evacuate. 4. Recharge with proper amount of R134a coolant and lubricating oil. The process is best left to a professional A/C shop.
    Sep 03 2015
    South Dakota
    What kind of bolt would fit the hose? #6 in diagram, I believe
    Feb 24 2004
    Minneapolis
    Don't know about the bolt. Go to a hardware store and buy 3 or 4 metric bolts that look right and try 'em. If you have 3 bolts left over you've wasted $2.50.
    Quote Originally Posted by Brillo View Post
    I agree with this, except have the shop pressure test it before the new dryer. If that residue means a leaky condenser you need to replace that before you close it back up and do a new dryer.
