Results 1 to 4 of 4
    Established Member Two Rings HenrikMeister's Avatar
    Apr 03 2016
    Norway
    How to remove trunk lid liner from B8 Avant?
    Hi forum,
    Im really stressed out and frustrated. I am trying to remove the trunk liner because I think the wiper washer in the rear is leaking...
    The outer ones are easy, using force and about 6 "diamond" clips are out of the frame. The problem right now are the two inner ones (not sure if two) which is hard to remove, I don't want to use too much force as I am afraid of breaking something. I cannot find any screws that hold this in place... This is btw an avant, and I can't find anything online!!!
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Check pm box, files are to big!
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Apr 03 2016
    Norway
    So guys, with a major help from Gunnark, I managed to remove the trunk liner.
    Step 1:
    -Open trunk, and remove the inner rear lights black plastic cover from the inside.
    -Open up the plastic hinge compartment and remove the hazard triangle.
    Step 2: Their should be 4 screws holding the whole liner which is located by the tail light and inside the hazard light compartment. Remove the screws (I didn't have any screws for some weird reason)
    Step 3: Pull firm but gentle on the lower trim part. (By pulling the side where the trunk latch is located). Their should be 3 diamond shape clips on each side of the hinge holding the liner to the trunk frame. You just need to pull.
    Step 4: You can now pull the liner that is close to the rear window. Their should be 2 on each side.
    Step 5: unplug the trunk light and the "close trunk" button.
    Voila. Done.
    Apr 03 2016
    Norway
