    Veteran Member Four Rings jerseybrian's Avatar
    Jul 15 2011
    2008 Audi A4 2.0T Quattro QG 6spd
    Boynton Beach, FL
    High mileage rear suspension issues?
    Hey guys
    I'm at 140k miles and I'm starting to hear some noise from the rear suspension. The shocks and springs were replaced earlier this year. When I jounce the car on the left hand side, there is a loud creaking noise coming from somewhere behind the driver's side rear brake rotor. Nothing from the left side. Has anyone had similar symptoms?
    REVO 2+ | VAST Meth | RAI HFC and 3" DP | Milltek S4 Exhaust | Autotech HPFP | 145bar PRV | JHM STS | BFI knob | 034 SD MM | ECS RA4 LWFW | ACT RS4 HDSS | QTP Cutout | Forge DV | APR Snub | Deval RS Front | Votexx 3pc wing | OEM Euro Bi-Xenons | Bilstein HD Shocks & ECS sleeves | Eibachs | RS4 RSB | S4 F&R Brakes | ECS S4 Slotted | Hawk HPS | ECS SS lines | FK LED Tails | CF Dipped Diffuser | Innovate LC1 | IE Billet | THULE | PODI
    Deactivated Four Rings
    Jun 23 2011
    I have a small noise, but it is the splash shield vibrating. I would check that or a bad rear shock mount? Did you change out the mounts with the suspension?
    May 20 2010
    Sometimes the dust shields get bent up when people do not pay attention to what they are doing. Take a look--it may be rubbing.
    Jul 15 2011
    Boynton Beach, FL
    Not the dust shield. I checked.
    Rear shock mount was replaced with new a Bilstein HD and Eibach spring
    I'll dig up my chassis ears if I have to....
    Established Member Two Rings shahk62's Avatar
    Jul 14 2015
    Sydney
    Quote Originally Posted by jerseybrian View Post
    Hey guys
    I get squeaking over bumps ... Still don't know what it is
    2005.5 B7 A4 2.0T Quattro - 034 RSB + End links, GFB DV+, 034 Snub, 034 Billet Rear Diff Carrier Mounts, BSR CAI
