    Oct 31 2013
    WA
    A6 Lower control arm on Allroaad
    So, about 3 years ago when i started this project, i bought lower control arms from a local vw/audi store, problem is that I'm having a hard time fitting them and I don't recall if I ordered these for "A6" or "Allroad", mainly because i was in the midst of installing all the A6 manual tranny stuff, and the suspension has been converted to non-air A6 prior to me.
    Anyway, when I compare the two control arms I notice that although the length is identical, the angle from where the strut connects over to where the hub connects is more extreme on the original allroad arms, probably 2-3 degrees of difference. Basically, the new ones i got are mostly straight, while the original allroad ones have a slight angle in that section.
    So my question is this, if the suspension is no longer air, shouldn't it be pretty much identical to A6? should I be able to use that control arm?
    Jun 10 2013
    United States
    My understanding is that you will need to use A6 uprights which are shorter and work with the A6 lower control arms.
    The difference with the allroad is taller uprights, longer lower control arms (maybe different angles) and body spacers.
    Oct 31 2013
    WA
    Thanks, but what are uprights? Not in tune with all the audi lingo...
    Veteran Member Three Rings carmudgeon's Avatar
    Oct 23 2012
    1995.5 S6 Avant
    Kansas City
    E.g. the spindle, or if you're old like me, the steering knuckle.
    Previous vehicles: 2012 TTS Roadster - 2017 Golf R - 2002 S6 Avant - 2013 S4 - 2008 Subaru STi - 2007 Mazdaspeed3
    Sep 11 2009
    NE
    upright = spindle
    The difference in the two arms is in how high, in relation to hub bolt <-> frame bolt straight line (perceived curveness of arm is irrelevant), the shock attaches. In allroad, the attachment point is lower than in A6. This is to allow for longer shock travel for adjustable suspension. And remember, spindle height has nothing to do with how "tall" the car will sit but ONLY with where the shock attaches. With given compressed shock length, the attachment point height is what moves chassis up and down and thus yield different chassis to ground clearance.
