Results 1 to 22 of 22
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Cayenne/Touareg 4 pot Rears
    Finally, someone has made a kit to bolt up 4 pot rears WITH a parking brake. Price is decent, but after everything you'd still damn near have $900 into getting them on.
    http://fablessmanufacturing.com/prod...-s4-1996-2002/
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    Those metal brackets look really thin and weak.... eek
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Dec 10 2013
    Borden, Ontario, Canada
    Yeah, they look hella thin compared to the other brackets they have
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Veteran Member Four Rings ray4624's Avatar
    Nov 27 2010
    mass
    I mean considering that apikol sells just the brackets for a front bbk for like 229 then this isn't a bad deal if it holds up
    Veteran Member Four Rings Wet0willy01's Avatar
    Nov 17 2008
    05 A4 USP, 00 S4, 01 A4, 16 A3
    The parking brake caliper mounts look to be thinner but the 4 pot caliper bracket seems beefier.
    -Andrew
    2005 Dolphin Grey Ultra Sport
    630AWHP HTA3582R 1.8L 93+ Meth
    Before camber and tire stretch, there was horsepower and performance.
    Jun 10 2010
    That's a good price.
    I'm curious if driveability would be affected (brake bias, ABS, etc.).
    Dec 10 2013
    You can code the brake bias to RS4 in VCDS
    IG: 24_et
    Sold:
    RIP:
    Jun 10 2010
    That wouldn't do much considering the calipers aren't the same.
    Veteran Member Three Rings pee quu's Avatar
    Jan 25 2009
    Oceanside, NY
    getting the caliper for the e brake would be the worse part. theres actually a full set of calipers for sale for I think 700
    2000 B5 A4 / C5 S6 V8 swap / B5 S4 driveline swap / PVW Nov 2016
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by pee quu View Post
    Dude, the calipers are less than $150/piece on rock auto. Would have to grab crossover pipes though. Ebrake calipers are less than $100 apiece.
    2000 S4- Working?
    Established Member Two Rings palpal b5 s4's Avatar
    Aug 03 2011
    b5 s4 single
    In the shop
    The e-brake brackets (at the top of the picture) are 1/4" which is more than enough material considering this just stops your car from rolling away when stopped. The brackets at the bottom of the picture are stainless steel and much thicker. These have good factor of safety on them and were designed by an Engineer. No concerns about safety on these. The very first kit has been going strong on a single turbo B5 for over 4 years with no issues.
    We have also sold a kit to a customer in Australia with a B5 race car which will be a really good gauge for the durability of our product.
    Aug 03 2011
    b5 s4 single
    In the shop
    We have been running this kit for over 4 years with no issues. The pedal feels the same and we didn't have to do any coding for the brake bias. It feels exactly like stock, just stops WAY better. :)
    Veteran Member Four Rings NeedingAnAudi's Avatar
    Mar 16 2009
    99.5 A4 4.2QM, 01 Nogaro RSFaux Avant, 15 Q7 TDI Sport Edition
    Valparaiso, IN
    I saw the post yesterday in the S4 owner's group and now I'm the proud owner of a set of used q7 calipers. So glad this kit was made, now I can match my 18z's
    Brilliant Black 99.5 A4 Project V8
    Nogaro Blue 01.5 S4 B5 RSFaux
    Glacier White 15 Q7 TDI Sport Edition
    Poopoo Brown 80 5000s Diesel
    Audi R8 certified technician - PM for work local to Chicago/Northwest IN
    Alex
    Dec 10 2013
    Quote Originally Posted by palpal b5 s4 View Post
    What happens if I lose my brakes and need to use the "EMERGENCY"-brake at over 100kph/65mph? Will they not bend out of shape if I suddenly need to use it?
    IG: 24_et
    Sold:
    RIP:
    Jan 16 2006
    LA CA
    I am worried that if I leave my parking brake on by accident it will be like a bomb going off. Be honest we have all done it more than a few times.
    Sent from my SM-N910V using Audizine mobile app
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    so was Chernobyl, the nasa Challenger, etc
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    I can't believe you guys are worried about the ebrake bracket. Its steel, what is going to happen to it?
    2000 S4- Working?
    Sep 12 2008
    South Central PA
    burst into flames and curse my mother
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Aug 03 2011
    b5 s4 single
    In the shop
    Thumbs up
    Quote Originally Posted by Bordom View Post
    The clamping force created by the Wilwood spot caliper isn’t enough to deform or damage our e-brake bracket. The surface area of the pad on the wilwood caliper can’t generate a great enough force to cause any damage to our brackets. You can use your e-brake like you normally would without any issues.
    Dec 10 2013
    Quote Originally Posted by redline380 View Post
    See quoted post below lol
    Quote Originally Posted by Dan[FN]6262 View Post
    IG: 24_et
    Sold:
    RIP:
    Aug 03 2011
    b5 s4 single
    In the shop
    I dont know what to say hahah
    Nov 27 2010
    mass
    Lol I haven't used my e brake in years. Cool looking product guys. Glad people are still making stuff for these cars.
