I am having a similar issue but it is only happening to the passenger side. Even though the driver side stays ice cold, the passenger side is warm with the same temp stpt. I believe my issue is either with the blending damper or the zone temperature sensor. If the damper is sticking and not moving to the correct position, the air could be warmer than it is supposed to be. Or if the temp sensor has drifted and is reading a value lower than actual, the damper will not be commanded to a position that will be cold enough.
It is possible that the evaporator is freezing up, however if this is the case you wouldn't necessarily lose cold air but you would lose the majority of your airflow all together because the path through the coil would be blocked. If the fan speed indicator is at full speed, but you feel little air than I would think that this could be the case. If the fan speed is at minimum when you expect it to be at maximum than again I would point to the temp sensors.
I haven't started to troubleshoot mine yet but I did just get the VCDS software and cable and it appears that you can look at the damper command and feedback position. So checking for a sticking damper should be able to be done through the software. I am not sure about the temperature sensors however.
Does anyone know if the dampers are electric or use pneumatic/vacuum to operate?
