Finally received by AWE Tuning Track Edition Catback exhaust kit from Excelerate Performance. Took a while to get it since I live in Germany and APO shipping isn't the fastest.
Sorry for the lack of photos and a dirty car. My phone died mid install and I only had an hour to get it done.
Removing the Exhaust was quick and easy. I got it done in about an hour using only jack stands and floor jack. Stock exhaust bolts came right off with little force used. Found it easier to remove the stock exhaust by removing the entire hangers from the car instead of forcing them off the rubber hanger. Exhaust dropped right out. Ensure you remove the valve actuator clips first and the ZIP TIE holding one on to the stock exhaust.
The stock S3 exhaust weighs in at about 53.5 lbs +/- a few lbs. Its not very easy to weigh as one piece.
The AWE Exhaust weighs in at about 45 lbs with all clamps and bolts. Only about a 8.5 lbs weight savings. Reason for this is the muffler used by AWE is quit a hefty piece at 22lbs by itself, but required for a sound it gives. The AWE Exhaust went in easily. I found it easier to install each part of the exhaust onto the car separate and leave them loosely attached for positioning.
Exhaust sounds deep and mellow. Not loud at normal driving but has a nice growl and snarl at high rpms. No drone. I was worried it might sound like a 4 cyl. fart-can exhaust by loosing the stock resonator, but it doesn't at all. No complaints. Great Sounding Exhaust.
