Results 1 to 8 of 8
    Jan 12 2010
    SE Pennsylvania
    Question Superficial scratches...Menzerna Heavy Cut 400 or 1000 or other?
    Hey all,
    I've got 3 superficial scratches on my hood, through clearcoat and a little bit into paint.
    Tried Meguiars Ultimate compound and a rotary buffer.
    Improvement but I can still see them when looking at certain angles.
    I ordered a DA buffer (TORQ BUF501X 10FX) and also considering a compound that will give better results with Audi's harder paint.
    I read great reviews about Menzerna products and about the Heavy Cut 400 that decreases in abrasiveness as it is worked into the paint,
    and that you can go straight to a glaze when done.
    Your suggestions will be appreciated...
    2014 S4 Prestige l Misano Red Pearl l Black Alcantara l DSG l Sport Diff l Carbon Inlays l 034 Solid Rear Sway bar w/ Moog End Links l Eurocode Trans Insert l ESC Rear Diff Inserts l CR-15 Strut Tower Brace l Uniden LRD 950 Mirror Tap l Chipwerke Pro
    Previous:
    1994 Ford Taurus SHO w/Yamaha V6, 5 Speed
    1999 Ford Mustang Cobra Convertible, Triple Black, 5 Speed
    2007 BMW 335i 6 speed l Tuned
    May 13 2016
    atl
    If its through the clearcoat i dont think using a buffer will help
    Sent from my SAMSUNG-SM-G928A using Tapatalk
    Veteran Member Three Rings Avus RS4's Avatar
    Apr 09 2015
    Niwot, Colorado
    If they're thru the clear, they're not superficial.
    If you can feel your finger nail across the scratches, meaning, your fingernail would catch into the scratch, then it's too deep to be buffed out.
    2007 Avus Silver Rs4
    Bone Stock
    Jun 17 2016
    Gaffney/SC/Upstate
    Agree with all the post, so I won't repeat. If they are swirls and from normal washes, then the FG400 from Menzerna is a great compound. With a rotary and ultimate compound, you could possibly be seeing the holograms that were put into the paint with the rotary, making you think that there are still scratches.
    The Torq DA would be able to pull these holograms out if that is indeed what it is. You could however continue down the road of buying and buying and scratching your head along the way. Do you have a local professional that you can work with?
    HUMP
    Jan 12 2010
    SE Pennsylvania
    Thanks for your replies.
    Just remembered that i used my rotary on my girlfriend's older hyundai.
    I hand applied the Meg compound to my hood.
    So, based on your comments, i should get touch up paint and try to fill in the scratches. And work it from there.
    Then consider taking it to a pro if the results fall short. correct?
    Thanks again.
    Previous:
    May 13 2016
    atl
    Quote Originally Posted by 4wheelpilot View Post
    Thanks again.
    I also would suggest not hand buffing the compound next time to save you some time. The compound needs to be worked in using a machine.
    Apr 09 2015
    Niwot, Colorado
    Thanks again.
    Is there any way you could post some pics?
    We're going by what you're describing, and that's subject to different interpretations, but if you have a chance to post some pics, we can give you some suggestions that best suit your situation.
    Bone Stock
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Thanks again.
    if you spray some clear detail mist on them and they go away, they are likely just in the clear. if they stay white or visible, it's likely through the clear. either way you can fill them and wet sand to level them out and buff to gloss. they should blend fairly well if done correctly. just take your time, tape them off.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
