Results 1 to 16 of 16
    Apr 13 2014
    israel
    2 gear shifting problem ...
    i swaped my 2.7t from auto to 6mt i used tdi gearbox
    when i drive normal 2 gear shift normal
    when accelerate hard cant get the 2 gear in there is no nosie no grind ,,,,, just cant get it in 2 gear untile i lose some rpm ..
    anyhelp
    Veteran Member Four Rings Austonwerner4's Avatar
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    Needs a rebuild.
    Single Turbo on it's Way
    PM me for 17z and 18z Caliper Needs
    Apr 13 2014
    israel
    can u give more info
    and u talking from experience ?
    thank u in advance
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    the 2nd gear synchros are bad, possibly the 2nd gear as well, depending on how bad and how long it's been grinding.
    Apr 13 2014
    israel
    it is not grinding when drive normal or when accelerate .........what another things can make the 2 gear not get in ...
    i will make video .... and post it here
    Veteran Member Four Rings mikeb17's Avatar
    Oct 27 2012
    Lamborfeetes
    Washington
    Hate to say it but it needs a rebuild.
    Apr 13 2014
    israel
    ok fro, where to buy the synchros ?
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    Here's a good YouTube video showing the bad 1-2 hard shift issue. Good luck a just had my 1-2 gears lock up on me.
    https://www.youtube.com/watch?v=etE85I8aKSs
    Oct 26 2011
    CA
    Quote Originally Posted by milanocito View Post
    I would buy them from Scotty at advancedautomotion.
    http://advancedautomotion.com/shop/p...products_id/88
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    Did you adjust the shifter and linkages after
    finishing up your swap? If the adjustments been
    done and you can't grab 2nd at all I concur on the
    rebuild. I'm guessing you bought a used TDI box
    as well. They are stout units but there's no telling
    what the jerk off before you did to it.
    - - - Updated - - -
    ^^Go with scotty's kit.
    May 16 2008
    South Texas
    Shifter linkage problems usually affect sets of gears, not just one. You could have a clutch that is not releasing but usually it shows up in all gears, and reverse is the one that is that is affected the most with a clutch problem.
    Or the tdi transmission you got was bad to begin with.
    Apr 13 2014
    israel
    Thank u
    Sometimes when i tray to get it in revers it is get in 1 gear
    The clutch and flywheel is new has just something like 200 km...
    Anyhelp
    Apr 13 2014
    israel
    I will check the engine and gear mounts maybe they affect
    Apr 13 2014
    israel
    I fixed it without touching the gearbox
    Veteran Member Three Rings rnagy86's Avatar
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    And what was the fix?
    Apr 13 2014
    israel
    the clutch switch
