Here is an aftermarket fuel system flow chart and parts list that I put together for people interested in installing an E85 high flowing fuel system. I highly recommend using carbon impregnated PTFE fuel hose like Earls speed seal. It doesn't weep fuel vapors like the rubber lined hoses.
***Also, you will not need the entire length of hose I included in the estimate as there is extra so you won't end up short. You can try an order less if you want to estimate the lengths you will actually need.
***The parallel setup could also be modified to use a dual inlet FPR, that way you could eliminate the need for am additional Y fitting in the feed lines. Adjust accordingly
PDFs: https://drive.google.com/file/d/0B3a...ew?usp=sharing
