We're pleased to announce the availability of our all-new Audi Q5/SQ5 Adjustable Solid Rear Sway Bar! These bars feature one-piece solid spring steel construction and two-way adjustability, and are in-stock and ready to ship.
034Motorsport Adjustable Solid Rear Sway Bar, B8/B8.5 Audi Q5/SQ5 & C7/C7.5 Audi A6/S6/RS6/A7/S7/RS7
Retail: $245.00 + Shipping
034Motorsport is proud to offer the ultimate rear sway bar upgrade for the B8/B8.5 Audi Q5/SQ5 & C7/C7.5 A6/S6/RS6, A7/S7/RS7! The 034Motorsport Adjustable Solid Rear Sway Bar is made from a single piece of high-quality, 23.8mm thick spring steel for maximum rigidity, and is designed to combat understeer while reducing body roll under hard cornering.
This product was tested thoroughly on the street and track on multiple enthusiast-owned Q5/SQ5 and C7 chassis Audi models before release. The 034Motorsport Adjustable Solid Rear Sway Bar substantially reduces understeer and body roll on B8/B8.5 Audi Q5/SQ5 & C7/C7.5 A6/S6/RS6, A7/S7/RS7 vehicles without compromising comfort on the street.
The 034Motorsport B8/B8.5 Audi Q5/SQ5 & C7/C7.5 A6/S6/RS6, A7/S7/RS7 Rear Sway Bar is engineered to be used effectively with the stock front sway bar. No upgrade in the front is required. The addition of a stiffer front bar can positively affect turn-in feel, but ultimately worsens the platform's tendency to understeer. With the stock front sway bar and upgraded 034Motorsport Solid Rear Sway Bar, body roll is virtually eliminated while turn in and off throttle oversteer are greatly improved.
Features:
- 23.8mm Diameter
- Solid Spring Steel Construction
- One-Piece Design
- 2-Way Adjustable
- Designed to be used in conjunction with the stock front sway bar.
What's Included:
- B8/B8.5 Audi Q5/SQ5 Adjustable Solid Rear Sway Bar
- Polyurethane Sway Bar Bushings
- Billet Aluminum Sway Bar Brackets with Integrated Zerk Fittings
- Sway Bar Bracket Installation Hardware Kit
Fitment:
- 2009 - Present Audi Q5 (B8/B8.5)
- 2012 - Present Audi SQ5 (B8/B8.5)
- 2012 - Present Audi A6 (C7/C7.5)
- 2012 - Present Audi S6 (C7/C7.5)
- 2012 - Present Audi RS6 (C7/C7.5)
- 2012 - Present Audi A7 (C7/C7.5)
- 2012 - Present Audi S7 (C7/C7.5)
- 2012 - Present Audi RS7 (C7/C7.5)
Installation Instructions:
Please Note: We recommend upgrading to our Spherical Audi Q5/SQ5 Rear Sway Bar End Links to attain the maximum performance benefit when installing this rear sway bar upgrade.
Please don't hesitate to contact us via PM or email if you have any questions!
You May Also Be Interested In:
Audi Q5/SQ5 Drivetrain Mount Insert Package
High-Flow Silicone Audi Q5/SQ5 Intake Hose
X-Brace Billet Aluminum Audi Q5/SQ5 Subframe Brace & Chassis Reinforcement
B8 Audi Q5/SQ5 Density Line Performance Engine Mounts
