Results 1 to 23 of 23
    Nov 08 2008
    Los Angeles, CA
    Somewhat Silly Question
    Hello - somewhat silly question here.
    Has anybody found an effective way to vacuum the inside of the car, right between the door sill and the glide rail for the seat? Unfortunately my vacuum cleaner doesn't have an attachment that is skinny enough to get in there. The rest of my interior is flawless, save for this one little strip of carpeting on both the driver and passenger side where five years of dust and debris has accumulated. Thanks!
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by A4Ultrasport View Post
    My wife bought a small vacuum cleaner made by Metro (I think it was this one) which has a fairly skinny attachment that fits into the area you mentioned if I remember correctly. It doesn't have the best suction, but it gets the job done for the car.
    SOLD 2015 Daytona Gray S4
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    Put the height of the seat bottom all the way up, or buy a skinny vacuum attachment for cheap online. Otherwise, remove the seat.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Maybe try putting a paper towel or toiler paper cardboard tube on the end of your vacuum cleaner hose and squeeze the end a bit?
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by jsh139 View Post
    Genius!
    Geoff
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    Quote Originally Posted by bakedziti View Post
    DO NOT EVEN CONSIDER taking out seat!! I got this one on close out sale from Advanced auto https://www.amazon.com/Bissell-Clean...bissel+car+vac .it has skinny attachment works like a charm for both my S4 & wife's lexus . I got it for 23 bucks
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    Quote Originally Posted by jygesq View Post
    You make it sound like his car will blow up if he takes his seat out... If you want to take the seats out to clean its pretty easy.
    My 2009 A4 Prem+ Build thread
    Aug 22 2014
    bloomfield,ct
    if you take seat out you must be careful of getting warning light about air bags. I think you have to disconnect battery first. Also seats are bulky , can be damaged or can damage other parts or car. Just to clean car? Why risk it. Just get a proper vac with proper nozzle. Easy
    Nov 08 2008
    Los Angeles, CA
    Excellent detailing hack ... this did the trick. Thank you.
    Veteran Member Four Rings KRp220's Avatar
    Aug 23 2011
    NH
    i have a narrow nozzle thing on my compressor so i just blast out any crap thats in there, then vacuum the debris
    2013 S4 // ESTORIL BLUE // 6MT// RS BUMPER // GIAC STG 2 // FORGE CC // AWE+SCORPION // ECS INTAKE // BILSTEIN+H&R // VOSSEN VFS5 // PSS 265/30/20 // AK // 034 MOUNTS // SB STAGE 3 CLUTCH // CR 15
    + ECS Diffuser, BFI shift knob, tints, sports diff, j-codes, Akebono pads, SS clutch line, Ceramic Pro...
    GONE 2010 S4 // QUARTZ GREY // 6MT // GIAC STG2 // AWE TRACK // ROC EURO // 034 TRANS MOUNT // H&R OE's // AG M610 FF 19x8.5 // + random stuff
    Veteran Member Three Rings 968Reckless's Avatar
    Sep 25 2010
    B8.5 S4, Porsche 993, BMW E30 s52 swap, BMW E30 vert, BMW 2002tii, gen 3 tacoma
    Syracuse, NY
    Harbor freight sells a kit with around 10 mini attachments that fit a regular vacuum. I think the whole kit is like $8.
    Edit: http://m.harborfreight.com/8-piece-m...not%20provided
    Use a 20% off coupon
    Sent from my beeper
    @martino_motorsport
    Dec 14 2015
    Orange County, CA
    I have found that my Dyson V6's crevice tool fits perfect between the sill and the seat.
    *GONE* 2016 S4, Premium Plus, BO Package, DSG, Sport Diff, Daytona Grey, CR-15 Strut Brace, EuroCode AK, 034 Trans Insert, ECS Drivetrain Inserts, 034 Rear Sway Bar, HRE FF01 19x9.5 Wheels, Brembo GT 380mm BBK, EPL Stage 1 & DSG Tune
    2020 BMW M2 Competition, M Drivers Package, White
    Apr 04 2012
    MSP
    Here is your solution - works quite well.
    https://www.amazon.com/VaccUFlex%C2%...uum+attachment
    Lots of uses -
    Aug 25 2013
    florida
    Quote Originally Posted by MrFunk View Post
    that looks like one of those items where once you buy it and it worked, you wondered why you never thought that idea originally.
    Aug 25 2013
    florida
    Quote Originally Posted by 968Reckless View Post
    Sent from my beeper
    I missed this link earlier, the reviews are a bit hit and miss but can't beat the price.
    Veteran Member Three Rings Pared's Avatar
    Oct 28 2010
    Don't take out the seats. That's just ridiculous, only to get in there...
    It's much better to take out the carpet.
    Aug 22 2014
    bloomfield,ct
    Quote Originally Posted by Pared View Post
    why bother to take out carpet. Just get thin nozzle for vac or vac with thin nozzle. It takes less than 5,minutes to vacuum car with proper vacuum cleaner with thin nozzle .
    Veteran Member Three Rings VenturiRS's Avatar
    Dec 27 2008
    That went over your head...
    B8.5 Estoril Blue S4 | P+ | DSG | SD | ADS | B&O | CF | Nappa | Advance Key | CF Badges
    Veteran Member Four Rings quietcropduster's Avatar
    Feb 21 2015
    2014 C7 Corvette 3LT Z51
    Ohio
    Micro Vacuum Attachment Kit - 7 Piece https://www.amazon.com/dp/B000BSJCLY..._4whHxbXKYE40P
    The best $7 u will ever spend on your interior car care. Very well made works well. Between seats air vents, window sills, the creases in your seats, cup holders, gear shifter, really anything honestly.
    double thumbin' it!
    B9 S4 Prestige | Glacier White Metallic | B&O | Sports Diff | CF Inlays | Roc Euro Intake | APR FMIC | ECS Valved catback | 034 tour brace/RSB & trans mount | Forge Motorsports OCC | Michelin PS4s | EPL Stage 2 93 |
    Aug 22 2014
    bloomfield,ct
    Quote Originally Posted by VenturiRS View Post
    you are right I missed the sarcasm .
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    No problem ;) It actually just came to me while reading your post and I did a web search to find a pic and low and behold it's already a life hack, haha.
    Mar 05 2015
    2009 A4 Cab: S-Line / 1996 Camaro Z28
    East Granby CT
    My favorite option is to remove the carpets - although that my not be enough - so why not also cut a whole in the floorboard so that the dirt will just fall out - and the wind while driving will also act as A/C - it's a two-fer option!!!!
    So not so "Silly Question" after all.. quite a few good responses
    2012 Moonlight Blue Metallic S4 | Premium + | DSG | 19" Peelers |Sports Diff | MMI w/Nav | B&O Audio | Advanced Key |
    After-Market Add-Ons: Rallitek Aluminum Paddles | USP LED Interior Lighting | Phillips Xtreme +50% Headlight Bulbs
    Performance Upgrades: 034 Stage 1 ECU & TCU | | APR I/C |
    Stoptech Cryo Slotted Rotors with Porterfield R4-S Pads |
    034 Springs / Koni Yellow shocks | Tires = Michelin Pilot 4S (255/35/19)
    Jul 07 2012
    Boston, MA
    I had none of these issues when I swapped my seats. I've taken them out and put them in at least 5 or 6 times during the swap... The passenger seat recognition module doesn't plug and play for all A4 and S4s. For the record not saying its easier to do, just saying if you want to go for the deep cleaning with like a steam vac and really get in there, taking the seats out is an option. I would probably opt for the vac hack over the seat removal. I'm not that anal when it comes to cleaning my car.
