Results 1 to 7 of 7
    Veteran Member Three Rings idrinkv8's Avatar
    Nov 01 2008
    2.0T AC Not Working at Idle, Temp Gauge Rising
    AC seems like it's struggling at idle. I noticed that the temp gauge stays in the middle with the AC off. When I turn it on I hear the freon start to circulate, the compressor click on, rpms drop slightly, then the AC blows slightly warm air and the compressor clocks back off. If I rev the motor up I can get the air to blow colder but the temp wants to rise up.
    I'm going to change the coolant temp sensor but I'm thinking its maybe the fan control module... Can I test this with the VAG?
    Nov 01 2008
    Help
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Sounds like a low Freon charge. Check and fix that first, before thinking you have a radiator fan issue.
    Nov 01 2008
    Quote Originally Posted by S4'ed View Post
    Thanks for the response. Major detail I forgot to add is that the car slightly overheats if I leave the AC on at idle because the fans won't spin fast enough. My gut is leaning towards the fan control module and my heart wants it to be the freon charge.
    Nov 01 2008
    Changed fan control module and coolant temp sensor, checked relays under ECU, nada. Pretty much seems like a fan issue at this point.
    Does anyone know if one fan goes out does the other also not work?
    Nov 01 2008
    For anyone that finds this thread, it was the fans.
    Active Member Two Rings hagerty47's Avatar
    Jan 08 2016
    Orange County, CA
    I'm having this same issue atm. Was there a way you diagnosed it was the fans or did you just replace them? I don't wanna start just throwing parts at mine.
