Results 1 to 4 of 4
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    2.7T - upgraded rods - wrist pin clip
    I have new rods etc on hand now and want to rebuild the bottom end.
    It was suggested to have new retaining clips for the wrist pin on hand (in case old ones are not reusable or get lost); just don't want to get 'stuck' in the middle of the job if they would be needed.
    Does anyone know how they are called, part number, quantity needed?
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Feb 20 2010
    Brighton, MI
    05 Golf TDI
    Dec 10 2013
    Borden, Ontario, Canada
    Why not post this in the B5 S4 or C5 A6 forum? You'd have much better luck
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by Bordom View Post
    I often do.
    i found the part number:
    N90558301
    Often called wrist pin circlip
    Checking how much from nearest dealer.
    05 Golf TDI
