What's up guys I have a 2002 tip a4 quattro with roughly 215,000 kms on it and I'm guessing that the fluid has never been changed so I naturally want to do it, but I've heard of horror stories about trannies breaking down after a change with high mileage. I also heard that this usually only affects older cars or american ones mostly so I'm not exactly sure if I should go for it. Now I know auto's slip naturally but mine acts kinda like a cvt and holds an rpm while the speedo climes, so I highly doubt this is normal and I know the atf in there is broken down and not doing any justice at all. My transmission act just fine, no hard shifts, delays, or trouble shifting from P through RNDS but I haven't tried tip mode because my rubber cover is stuck and the little magnet attached to it isn't there to let the car know I'm in tip mode. So as far as it goes I don't need to change the fluid and I would hate for that to stir something up. I am not doing a flush or a complete change in fluids, just a drain drop the pan, change the filter and then put it back on and fill it with fresh fluid. Or I might just do a drain and fill, but I'm not sure what to do or if I should do anything really. Anyways guys go ahead and drop those ideas down there for me, thanks
