Results 1 to 10 of 10
    Senior Member Three Rings wildtouch83's Avatar
    Mar 04 2013
    United States
    Girodisc RS5 brake pads
    anyone out there ever use these? Price is pretty good at $250 for the fronts. They have plugs for the pad sensor. Girodisc claims less dust and good initial bite.
    I was considering pairing them up with the ECS true float wave discs.
    I was going to to the Girodisc rotors as well, but, my 18" winter wheels won't clear those 380mm rotors. And I'm not going to invest in another set of wheels and winter treads lol
    Open to any feedback anyone may have about their pads though! If there isn't any info out there, I may have to go with the Carbotech 1521 pads. There are a number of folks on this board that like those.
    cheers!
    2018 Nardo Gray TT RS - SOLD
    2018 Manhattan Gray Q5
    2006 A4 Avant - RIP
    2013 Phantom Black RS5 - SOLD
    Veteran Member Four Rings chrissurfr's Avatar
    Apr 26 2005
    Houston
    I'm on the hook for a new set of rotors and pads again...ugh...so I'm in for reviews....
    2017 Cement Grey TRD Pro 4runner
    2014 Suzuka Grey RS5 >:)
    • AWE Track Exhaust with center muffler straight piped
    • H&R Street Coilovers
    • BBS CH R - Gold with red caps
    • eCode headlights
    • Eventuri intake
    • JHM Stage 2 ECU/TCU
    • other things I forgot about
    Mar 04 2013
    United States
    I came across an older thread of yours earlier but the details are escaping me at the moment...what was the last brake rotor/pad setup you were running?
    2006 A4 Avant - RIP
    Apr 26 2005
    Houston
    rotors with 10k on OEM pads. replaced with hawk pads on 10k rotors....rotors now vibrating at low speed. the cheap way out didn't work...need to replace both meow
    • eCode headlights
    • Eventuri intake
    Veteran Member Four Rings adbender's Avatar
    Jun 13 2009
    2021 911 Turbo and 2023 Q5 Technik
    Girodisc seems like an excellent solution.
    1300 - fronts and 800 for replace rings (pair)
    700 - rears (pair)
    I also like the spring nut mechanism to handle temperature extremes.
    First on my mod list rigt now....
    2024 S5 Sportback Technik
    2023 Q5 2.0 Technik
    2018 Q5 2.0 Premium Plus (Totalled)
    2015 RS5|Stage 2 (Sadly Sold)
    2013 Q5 2.0T|Premium Plus (Sold)
    2010 S4|6MT|APR Stage 2+Everything (Loved but Sold)
    2005 A4 UltraSport (My First)
    Mar 04 2013
    United States
    It is adbender. And if I didn't have 18" wheels to run in the winter time, I would consider installing the Girodisc rotors as well. Alas, my wheels will not clear them.
    chrissurfr - I have decided I am going to pair the Girodisc front pads with some brand new ECS true-float rotors.
    2006 A4 Avant - RIP
    Mar 04 2013
    United States
    well, for the couple that are in this thread, I placed my order today. I opted for the ECS tru-float rotors and for pads I decided on EBC Red Stuff.
    once they arrive, I'll get everything installed, bedded and see if I made a good choice!
    2006 A4 Avant - RIP
    Oct 21 2009
    OC CA
    I am also going to have to replace my rotors and pads...how much did you pay?
    Mar 04 2013
    United States
    Quote Originally Posted by TTGTOVR4 View Post
    If you go with the same stuff I did you are looking at just over an $1,100 bill for the pads and rotors.
    2006 A4 Avant - RIP
    Mar 04 2013
    United States
    ECS true float rotors and EBC red stuff pads installed today!
    https://imgur.com/9yzuIF5
    2006 A4 Avant - RIP
