Results 1 to 24 of 24
    Veteran Member Four Rings CONative's Avatar
    May 06 2015
    B8 A4 Avant / Subaru Outback Limited / Honda Odyssey
    New Bilstein shocks already failing? Need input
    Background: my buddy and I installed the Bilstein B12 Pro Kit 2 weeks ago. Per Bilstein I removed the front bump stops and trimmed the rears. Only had some minor knocking from front passenger but nothing major. Pulled the wheel, everything was snug tight. Friday I had an alignment done and ask the shop to see if they notice anything - they don't. Drive the car home, now I have rattling coming from both sides. Pull the wheels, everything looks good on both sides, even placed a jack stand underneath and used the floor jack to life the rotor and still looks good.
    Next day I take my buddy for a ride, he thinks the alignment shop did something. Parked car and when I come back out an hour later I have a pool of fluid on my driveway. Pull the wheel again - it's hydraulic fluid coming from the shock. Way more so on the left but visible on the right as well.
    Anyone else ran into this issue? Could the alignment shop done something to create this issue? I plan on calling Bilstein this morning but wanted to get input from the community as well. This wasn't my first rodeo and used every resource on this forum as well as the stasis guide and st guide from ECS for guidance along the way.
    TIA
    Cheers,
    Ry-man
    Senior Member Three Rings NLPed68's Avatar
    Jan 21 2016
    1968 Chevy C10 Restomod, 1974 Bronco Crawler
    Hayden, AL
    That's nutz!! I don't like hearing this as I also just received my B12 kit after a multi-month wait and I'd hate to have to go through this too. Keep us up to date in what Bilstein says.
    Thanks,\
    Ed
    2012 A4 Avant... APR K04 /c APR tune, B&B catback, 034 HFC, 19" Avante Garde M510's, Bilstein B12 kit, Eurocode F&R swaybars/endlinks, Alu Kreutz, RS4'ish' Grilles, ERON rearview camera, EuroCode FMIC & plumbing, Kohlefaser Luft-Technik intake System, Ross-Tech VAGCOM, R8 coils, S-Line steering wheel /c paddle shifters, S4 F&R brakes /c drilled & slotted rotors/EBC's/stainless lines, LED taillights, Not a Mod, but WeatherTech laserfit floormats, 20% Tint, More to follow
    Veteran Member Four Rings Zach L's Avatar
    Feb 24 2010
    Austin, TX
    Bilstein makes great products, but if you keep having issues consider Koni Yellow Sport shocks. The best shocks I've owned. Even after 160,000 miles, they ride butter smooth. Damping is adjustable and they are nearly bulletproof. That's why they haven't needed to update the design in 30 years.
    Daily Driver: B8 A4 quattro 6MT, Aruba Blue on Black, Premium Plus, Sport Package, Bang & Olufsen
    Current Projects: 2006 Cayman S 6MT • 2006 VW GTI 2.0T 6MT • 1997 VW Golf • 1982 VW Rabbit Diesel • 1972 VW Bay Window Bus
    Established Member Two Rings rob_23's Avatar
    Aug 20 2013
    Vancouver BC
    Quote Originally Posted by Zach L View Post
    I concur. My Koni's have been awesome.
    2010 a4 Premium | 6 MT | Meteor Grey Pearl | Tinted | Rear lip spoiler | CF interior trim | LED plate lights | RS4 Grille | H&R OE Sport Springs | Koni Yellows | aFe | 034 | Apikol
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Why did you remove the front bumpstops? I think you blew the strut by not having the front bumpstop installed. I have never seen any installation instructions provided by Bilstein that say "remove bumpstop".
    Stage 1 more than you RS3
    Senior Member Two Rings ECDT's Avatar
    Jul 15 2015
    Philadelphia
    +1 for Koni I run the konis with h&r oe's
    May 06 2015
    Quote Originally Posted by o1turbo30v View Post
    I removed as I was told that the front shocks have built-in bump stops and by not removing the ride may be harsher. This was debated on many threads, a few which you chimed in on which you mentioned you did not remove yours. But without a solid answer I called Bilstein US Aftermarket & Motorsports to hear it straight from the horses mouth. The answer I got was the front shocks have internal bump stops and the rears are designed to reuse the OEM.
    Spoke with warranty this morning - had to send them vehicle info, any aftermarket mods and a picture of the shock - TBD.
    Cheers,
    Ry-man
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    I think only the rear bump stops need to be trimmed. @4ringnut may be able to advise further.
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    May 06 2015
    Quote Originally Posted by Project Quattro View Post
    Thanks man. It was his post that pushed me to call Bilstein before the install.
    http://www.audizine.com/forum/showth...n-Sport-shocks
    And Bilstein reaffirmed his post. But hopefully he chimes in.
    Cheers,
    Ry-man
    May 06 2015
    *Update*
    Bilstein is providing me a set of front replacement shocks at no charge - of course need to send the defective units back for evaluation. Warranty dept. was stunned as well but they are taking care of it. Another case of great customer service brought to you in part by Bilstein.
    Cheers,
    Ry-man
    Jan 21 2016
    Hayden, AL
    That's great to hear, but sucks that you'll be down for some time.
    Thanks,\
    Ed
    Veteran Member Four Rings 4ringnut's Avatar
    Apr 04 2015
    2019 Audi S4, 2017 Acura MDX
    Woburn, Ma
    The b8 sport shocks have internal bumpstops which prevent them from getting damaged at full impact. It does not prevent the top of the shock crashing into the shock mount. Bilstein did confirm that the stock front bumpstops are not needed with the b8 shocks. But after bottoming out several times I installed the trimming from the rear stops in the front (1.2"). Problem solved. As far as the blown shock. It happened to me too. It blew the second I lowered the car off the Jack right after the install. Red fluid all over the wheel well. Take pics, and file a claim with Bilstein. They sent me a new shock in less that 3 days, and it's been smooth sailing since
    - - - Updated - - -
    Only the fronts have internal stops btw.
    Pedal Responce first responder.
    Apr 04 2015
    Woburn, Ma
    Btw Konis are not as good matched with the eibach springs.
    Jan 21 2016
    Hayden, AL
    My last experience with Koni's on an Audi (my 2000 S4) was ridiculous. Yeah they were adjustable, but the adjustable dial wasn't accessible without serious difficulty. And my yellow front inserts on my E30 M3 blew second track day. I have a better luck "history" with the Bilsteins. I hope everything works out for the OP and I'll be chiming in once I put mine on in the near future.
    Thanks,\
    Ed
    May 06 2015
    Quote Originally Posted by 4ringnut View Post
    - - - Updated - - -
    Thanks for chiming in @4ringnut. Reaffirmed what Bilstein told me as well - front have internal but rears do not. Lisa in warranty is taking care of me - had pics and everything ready to go when I called. I leave for a road trip Friday so she's trying to get the replacements before then.
    You say red fluid though? I'm seeing fluid that resembles the color of brake fluid. But ruled out anything brake-related - have pulled wheel multiple times now since OCD has kicked in.
    Cheers,
    Ry-man
    Apr 04 2015
    Woburn, Ma
    It's a reddish fluid, similar to our coolant. If you blew a shock the oil will collect on the bottom of it. And you should see splatter all over the wheel well
    Apr 04 2015
    Woburn, Ma
    Wait I may be wrong about the color. I thought it was reddish.
    Apr 04 2015
    Woburn, Ma
    May 06 2015
    To give you an idea - fluid has soaked axle shaft, lower control arm etc.
    You say you started without front bump stops but eventually took the 1.5" you trimmed from the rear and added to the front? And ride quality has been smooth since?
    Cheers,
    Ry-man
    Feb 06 2012
    Allentown, PA
    Interesting how both you and 4ringnut didnt install the front bumpstops and the strut blew the instant you lowered the car. I wonder if Bilstein needs to change their advice to us.
    Its good to hear that they are taking care of you, thats cool.
    Apr 04 2015
    Woburn, Ma
    Interesting how my shock blew without even being fully compressed the first time I lowered my car from the jack. And then I had zero problems for over a year after bottoming out the shocks multiple times with no front bumpstops. Shit happens. They sometimes come faulty from the factory. I'm still technically not running bump stops. I really wish you stopped putting your 2 cents into these threads. I've had multiple members follow my install set up, and all had the same positive results.
    Apr 04 2015
    Woburn, Ma
    Quote Originally Posted by CONative View Post
    Both sides?
    May 06 2015
    I didn't really have any issues until I took it in for an alignment, drove almost 2 weeks, 100 miles give or take, before I had the alignment done. Wasn't until after I got the car back did I notice additional noises and then next day the pool of fluid.
    But great customer service - went out of their way to expedite shipping, new set should arrive tomorrow morning.
    Cheers,
    Ry-man
    May 06 2015
    Both sides?
    Unfortunately yes. Driver was more apparent first, then passenger. Ironically enough, the alignment shop said the driver side side was worse then passenger and that's where the knocking noise became more apparent - low and behold hydraulic fluid.
    Now I get to put my new power washer to good use trying to rid my driveway and garage floor of these stains - yippee.
    Cheers,
    Ry-man
